Tube Buffer IGC - need help ....
Old 14th November 2003, 09:54 AM   #1
Will is offline Will  Malaysia
Default Tube Buffer IGC - need help ....
I have followed and built the Tube Buffer circuit based on the JLTi DIY version.
Initially I misunderstood the PSU for the Tube buffer and connected
a single pair of +/-35v to both channel of the 6922's Pin, which when
powered up, created loud noise/buzzes like a mis-tuned AM radio.
After rectifying the problem, I built another +/- 35V and that solved
the buzzes, no more hum.
Now the problem is, even after validating that I'm getting the correct
voltages on all pins, I only get the faintest amount of music coming
thru my test speakers. I'm using a single tx with 24-0-24 v for the
tube, a single 12v tx rectified with 7808 with 7.1ohm resistor in series
to the filament.
What could be wrong ???
PS: The amplifier section was built weeks earlier based on the non-tube
version of JLTi and it was making music, so I kinda rule out problems
relating to the amp section.
will.
Old 14th November 2003, 01:15 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Hi Will,
For starters can you tell us if you are using the circuits shown on my VBIGC page ?
I don't use the resistor after the 7808 although I can't see that it would make much difference.
Don't worry, I am sure that we can solve your problem and when we do, it will have been worth the trouble!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 14th November 2003, 09:37 PM   #3
PRR is offline PRR  United States
PRR's Avatar
> validating that I'm getting the correct voltages on all pins
List pin-numbers and exact voltages. Yes it is tedious to type all that, but you need someone else's eyes to look at your work and see if there is an error. Could be as simple as mixed up pin numbers.
Does the tube light up with an orange glow in its center?
And remember it will take 10 or 20 seconds for the tube to warm-up and start working. Apologies if you knew that, but I've met a few people too young to remember tube warm-up.
Old 15th November 2003, 12:18 AM   #4
Hi Nuuk and PRR,
Thanks for you replys. Yep I did follow the circuits based on your website. Infact I have read your advises several times and indeed made just that. The filament and tube PSU are connected directly to the mains just like the JLTi hence the adequate warm up time.
OK to cut things short, PROBLEM IS SOLVED !!!
Of all things that I have checked e.g. voltages, soldier connections, reading the forum from front to back and back to front and even taking the trouble to change both the LM3875 pins, IT WAS MY DARN TEST SPEAKERS !!! I must have damaged them during my first startup which ended up in huge buzzes..... duh...
Right, coming back to the amp, here's what I've noticed from the non-buffered to the bufffered version :
1) Better overall air and more refined highs
2) Switch on thump
3) Louder humm...
I was thinking of regulating the +/-35 volts for the tube, is it possible to use a 28v dual secondary tx pumping thru only LM317s (I have a whole bunch of them) on the +ve and -ve rails to get 35v ?
will.
Old 15th November 2003, 09:28 AM   #5
Nuuk's Avatar
That's better Will, at least you have something coming out of the speakers now!
As regards your findings, I agree with number 1.
As you probably know, I use speaker protection which doesn't connect the speakers until well after I have powered up so I don't get a switch on thump.
I do get slightly more hum than with the 'basic' IGC. My findings having tried several different configurations of IGC is that the quietest version (least hum/no switch onthump) is with a wire from non-inverted input to ground. With Joe's circuit we have the 1 meg resistor to ground and I have found that although this arrangement decreases DC offset, it does increase hum and switch on noise!
So how bad is your hum. Mine is only audible close to the speakers which are very efficient full-range units in open baffles which is going to ruthlessly expose any such noise anyway!
Old 15th November 2003, 04:47 PM   #6
I can live with the switch on thump, but not the hum; thanks for tip, will try bypassing the 1meg. The hum is pretty audible about 1 feet away from the speaker. Yeah perhaps I ought to pay more attention to my grounding.
Today I tried a voltage regulator for the tube with a LM317/337 regulator to get +/- 35 v (using a single 30-0-30v Tx). Am pretty disappointed with the results , not sonically, but the noise I get that is worser than hum, sounds more like digital buzzes. I'm using 1000uf on the front and 470uf on the final, with 1uf film caps for bypass, which I think should be adequate enough for a silent operation. Have you any experience with those ?
will.
Old 15th November 2003, 04:54 PM   #7
ronc is offline ronc  United States
All , or just about all, problems i have had with IGC,NIGC and CBIGC (chip buffered ,gonna start a new phrase) have been grounding.
Either that or just plain ole dumb mistakes.
ron
Old 16th November 2003, 07:59 AM   #8
OK so I've verified all grounding connections and they appear to be properly connected and still, the regulated tube buffer supply is giving out digital buzzes. Any other suggestion on circuits which I can use to regulate the +/-35 supply ?
Old 18th November 2003, 05:26 AM   #9
Just an update, I have removed the voltage regulators, replaced the Tx with 30-0-30v, and a 2K2 resistor (instead of 220R) between a 1000uf and 470uf cap. Overall, am getting a voltage of around 36.8v on the tube, and the amp is buzz free. Hmmm, speaking about wrong regulator application.
Old 18th November 2003, 09:14 AM   #10
Nuuk's Avatar
That's good news Will! Do you have any pictures of your amp yet?
Tube Buffer IGC - need help ....Hide this!Advertise here!
Tube line-buffer for cd Tube Addict Tubes / Valves 28 18th April 2013 04:42 AM
Tube buffer before pre-amp/amp? Destroyer OS Instruments and Amps 2 9th January 2009 08:09 PM
Tube buffer PCB for LM3875 neil_kaye Chip Amps 0 28th August 2006 04:20 PM
Tube buffer NickC Tubes / Valves 3 9th May 2002 12:20 PM
Copyright ©1999-2017 diyAudio
