lm1875 fizzing away probelm lm1875 fizzing away probelm - Page 2 - diyAudio
View Poll Results: Was a good idea to use two lm1875 or a big stk chip
Use stk 8 26.67%
use lm1875 22 73.33%
Voters: 30. You may not vote on this poll
Old 5th January 2013, 08:56 AM   #11
PetruV is offline PetruV  Romania
I think the chip is dead it makes a very loud thinking noise even when its not hooked up to my computer,when i conect it to my computer the noise still continues and distorts the music
Old 5th January 2013, 09:10 AM   #12
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
I wouldn't use those ceramic capacitors . They are good for suppressing HF noise on the supply line, and they do the same duty well for reducing bandwidth at input (LP filter) of amplifier .
Use plastic dielectric ones...polyester, styrene, ecc for a Vl of 63-100 V.
Old 5th January 2013, 09:43 AM   #13
Oh thats why it sounded not bassy when it worked!
Old 5th January 2013, 07:25 PM   #14
Can someone post a good schematic here,with not a lot of components and mostly with the components that are on the schematic just swaped around
Old 5th January 2013, 09:58 PM   #15
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
http://www.ti.com/lit/ds/symlink/lm1875.pdf
Old 6th January 2013, 08:16 AM   #16
I think il use danielwritesbac veroboard version,but my soldering iron burned up since i worked too much with it since i was desperate to her the amp,in coupe minutes il go to the shop with my dad and i will return most probably succesfull in one hour
Old 6th January 2013, 10:34 AM   #17
got a new soldering iron and its so good wow,much better than my old one
Old 6th January 2013, 11:08 AM   #18
You can raise the value of the input capacitor .
That will increase bass . 1 till 3 uF are ok
Old 6th January 2013, 01:05 PM   #19
This is the schematic im building now,i got a new soldering iron and its so awesome!1!!1
Old 6th January 2013, 02:38 PM   #20
This one is now symmetrical supply.
lm1875 fizzing away probelmHide this!Advertise here!
Hiss probelm on JLH class A rchung Solid State 8 8th January 2013 04:44 PM
Preamp for LM1875 tom91 Chip Amps 3 26th July 2009 03:08 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
offset probelm in bugle phono preamp dre Solid State 5 13th April 2003 06:41 PM
Copyright ©1999-2017 diyAudio
