lm1875 fizzing away probelm
View Poll Results: Was a good idea to use two lm1875 or a big stk chip
Use stk 8 26.67%
use lm1875 22 73.33%
Voters: 30. You may not vote on this poll
Old 24th January 2013, 04:14 PM   #171
PetruV is offline PetruV  Romania
Originally Posted by picowallspeaker View Post
PetruV we're happy to know that you're still alive !
i got zapped a million times from my computer psu building a static charge
Old 24th January 2013, 07:00 PM   #172
I made an amp with this schematic and c8050 and it draws to much current from the input causing my test radio's power led and display to dim with the beat that not happening when there is nothing hooked up to the radio or the volume turned down,the radio has an inbuilt speakers which turn on when the jack is unplugged
Ps the transistor dosent even get warm
Old 25th January 2013, 05:04 PM   #173
noanswers sad face
Old 25th January 2013, 09:43 PM   #174
Just finished my lm1875 when i power it up it makes a buz and raws a lot od current,the power led goes dim,but if i turn it off and on in an instant the led goes bright the test lamp goes bright for a split sec and everithing is ok,could this be because of the lightbulb limiting the current ant the chip amps drawing a lot of current during power up causing it to kinduf run out of power and try and start and run oout of power and start up infintely
Old 26th January 2013, 11:45 AM   #175
It causes the radio that i test it with to lose signal when i plug it in the amp,maybe because the center tap of the transformer is used as ground
Old 26th January 2013, 01:12 PM   #176
why ARENT ANY ANSWERS IS EVERIBODY DEAD SAD FACE
Old 26th January 2013, 03:26 PM   #177
I finished it and its working and im proud of it i have
DONE IT MYSLEF
Or as tekko would say MY LIFE IS COMPLETE
but lets dont stop here i got to make a transistor amp and a high power 5.1 amp using an apex b500 or something like that for the sub chanel.That would require one hell of an transformer,But stay tuned for more!
Old 26th January 2013, 04:21 PM   #178
Just listening to it and the trebles are amazing but the bass is weak ,also the mids are very spatial,but there is an small distorsion which sounds weird maybe beacause the wires are bundled togheter to close,By far the best amp i ever heard,even better than my computer psu tda 8560q which led the previous record soundig better than the 1000 of dolars sound systems i had heard ove the years.
The lm1875t is weak,not very bassy altough used in an sub plate amp i have
But the other sounds are amazing and spatial,but that distorsion bugs me a lot
Old 26th January 2013, 06:29 PM   #179
no answers
sad face Click the image to open in full size.
Old 30th January 2013, 08:17 AM   #180
Any answers
lm1875 fizzing away probelmHide this!Advertise here!
Hiss probelm on JLH class A rchung Solid State 8 8th January 2013 04:44 PM
Preamp for LM1875 tom91 Chip Amps 3 26th July 2009 03:08 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
offset probelm in bugle phono preamp dre Solid State 5 13th April 2003 06:41 PM
Copyright ©1999-2017 diyAudio
