lm1875 fizzing away probelm
View Poll Results: Was a good idea to use two lm1875 or a big stk chip
Use stk 8 26.67%
use lm1875 22 73.33%
Voters: 30. You may not vote on this poll
Old 21st January 2013, 01:27 PM   #161
PetruV is offline PetruV  Romania
Im 13 but i have been woking with 220v since i wad 9 so im very experienced
Old 21st January 2013, 04:32 PM   #162
Originally Posted by blu_glo View Post
- did the attenuator work ok?
No it didnt the buzz is still there,but only when something is hooked up to it
Old 21st January 2013, 06:36 PM   #163
whoops i think it is so because i had pu it the wrang way around
Old 21st January 2013, 07:20 PM   #164
Blu glo your attenuator was a piece of crap causing a lot of noises,sorry for sounding rude but thats the truth
Old 23rd January 2013, 09:55 AM   #165
Actually the probem is because of the crappy rca cabble not carriing ground,those rca to 3.5mm cables are expensive and hard to find so my friend is not going to be able to get a working birthday present from me
Old 23rd January 2013, 07:39 PM   #166
Default Vacum tubbes !!!
Can i do anything with these things?
Old 23rd January 2013, 07:45 PM   #167
ALSO can anyone sugest a good simple class a amp using these small transistors, i have some bigger ones,but show me your schematics first
Old 23rd January 2013, 10:27 PM   #168
The best one of the transistors seems to be the c8050 at 1.5 a max
Again no answers? sad face
Old 24th January 2013, 09:24 AM   #169
The fastest and easiest thing to do is put a 0.1uF capacitor in parallel with 22-100 ohm resistor between 0V RCA inputs and the metal chassis. The metal chassis should be earthed at all times, please see my above post about working with mains.
That would get me into a ground loop,i aleardy cut the ground wire to my computer psu which powers my amps to stop this pluss that amp dosen have a ground plug
Old 24th January 2013, 09:50 AM   #170
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
PetruV we're happy to know that you're still alive !
lm1875 fizzing away probelmHide this!Advertise here!
Hiss probelm on JLH class A rchung Solid State 8 8th January 2013 05:44 PM
Preamp for LM1875 tom91 Chip Amps 3 26th July 2009 04:08 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 03:26 AM
offset probelm in bugle phono preamp dre Solid State 5 13th April 2003 07:41 PM
