lm1875 fizzing away probelm - diyAudio
View Poll Results: Was a good idea to use two lm1875 or a big stk chip
Use stk 8 26.67%
use lm1875 22 73.33%
Voters: 30. You may not vote on this poll
Old 4th January 2013, 08:03 PM   #1
PetruV is offline PetruV  Romania
Default lm1875 fizzing away probelm
This is my thread in which i will post all of my work and ask for all of my help.Sadly you cant change the name of the thread,go to last page to see my latest problems
Please excuse my excessive amount of demanded attention,that has been pointed out to me.
Old 4th January 2013, 08:34 PM   #2
The black puddle above the 100k resistor at the input is a ground
Old 4th January 2013, 08:37 PM   #3
Old 4th January 2013, 08:52 PM   #4
bobodioulasso's Avatar
Pin 1 must be at Vcc/2.
Why the two 100k resistors marked red on your schematic? They provide Vcc/2 at input pin.
You need them and the ground can't be as you made it.
Old 4th January 2013, 09:27 PM   #5
I was tired and i thought they werent needed and i wanted to see how it sounded,it took me 2 hours to solder all that crap in cause my soldering iron sucks and i never used perfboard
Old 4th January 2013, 10:45 PM   #6
You must follow the schematic for single supply.
Have a look at datasheet.
When +/- supply is used those resistors are not needed because the input pin , referenced to ground is at Vcc/2.
When a single supply is used a Vcc/ 2 point is created with two equal resistors (and a cap).
Old 5th January 2013, 02:45 AM   #7
Helpful hint: When a manufacturer says parts are optional they can be safely omitted but don't make changes unless you fully understand.
G
Old 5th January 2013, 08:06 AM   #8
G
I udestood it but i did the modification that was marked in red and it now works
Old 5th January 2013, 08:42 AM   #9
Now works did the scematic as in the image and adding the componets in red
Old 5th January 2013, 08:43 AM   #10
It broke,it makes a lot of sounds even when its not hoked up to my pc,i think it starts to oscilate making a very loud noise
Hiss probelm on JLH class A rchung Solid State 8 8th January 2013 04:44 PM
Preamp for LM1875 tom91 Chip Amps 3 26th July 2009 03:08 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
offset probelm in bugle phono preamp dre Solid State 5 13th April 2003 06:41 PM
Copyright 1999-2017 diyAudio
