| Chip Amps Amplifiers based on integrated circuits |
| View Poll Results: Was a good idea to use two lm1875 or a big stk chip | |||
| Use stk |
8 | 32.00% |
| use lm1875 |
17 | 68.00% |
| Voters: 25. You may not vote on this poll | |||
#61 |
I would have thought an op-amp oscillator is easiest to get working, but if you insist, Rod Eliott has offered a four transistor AF oscillator design
Audio Test Oscillator which looks very good (as are all his articles). A circuit can be done with only two transistors but the ones I've come across using google briefly appear to have some fundamental flaws. This is what happens when people rely on computer simulations too much and not the good old "solder-and-and-try-it-out" method!! |
#62 |
I had found a radio,just need to find batteries for it
#63 |
I dosent work but i think itsbthe radio
#64 |
An
STK412-170 would seem awesome,anyone can please post an schematic with layout and most importantly,are they good?! |
#65 |
im starting to do this design
,but how do i put this on veroboard ,since the holes line up to the layout![]() please any replies |
#66 |
I think you'll save yourself a lot of aggravation spending cash on a pair of unassembled printed circuit boards.
As I already said, LM1875 is directly interchangeable with TDA2030, 40, 50 types. I seen PCBs for around €10 or so! You can then tweak components knowing the wiring's already done right for you! TDA2030A Amplifier Amp board Components DIY kit BTL/OCL | eBay |
#67 |
#68 |
#69 |
Using this schematic the speker goes up and there is a faint trumpet noise,while nothing is hooked up to the input ,may this be becaue i used 55k instead of 50k
#70 |
| Hiss probelm on JLH class A | rchung | Solid State | 8 | 8th January 2013 04:44 PM |
| Preamp for LM1875 | tom91 | Chip Amps | 3 | 26th July 2009 03:08 PM |
| lm1875 | siemensc65 | Chip Amps | 4 | 23rd May 2006 03:28 AM |
| Lm1875 | soundNERD | Chip Amps | 14 | 12th October 2003 02:26 AM |
| offset probelm in bugle phono preamp | dre | Solid State | 5 | 13th April 2003 06:41 PM |
