Newbie question - can I use my pc 24V 10A power supply for TDA2050 or LM3886 amp
Old 29th December 2012, 04:17 PM   #1
iinself is offline iinself
Default Newbie question - can I use my pc 24V 10A power supply for TDA2050 or LM3886 amp
I am just starting to play with electronics and decided to build a very simple amp. I am looking for something around 20W of power but am interested in a nice clean sound. Could I use an old pc PSU with 24V/10A/150W max rating for either a TDA2050 or LM3886 amp.
Any suggestions greatly appreciated.
Arvind
Old 29th December 2012, 04:25 PM   #2
Mooly's Avatar
For several reasons its not ideal.
What you really need is a dual or split supply that gives equal positive and negative rails. Your computer supply is a single rail and this means you must use a circuit configuration for the chip amp that is specifically designed for this type of single rail.
Also switching supplies bring there own issues such as being electrically "noisy" generating high frequency hash.
A small 100 to 150va toroid and two moderate sized reservoir caps of say 3300uf to 6800uf would be ideal. Voltage rating to suit the chip you decide on.
Old 29th December 2012, 07:55 PM   #3
Thanks.. I was hoping to not mess with PSU part of the project..
Old 29th December 2012, 08:14 PM   #4
DUG is offline DUG  Canada
OR
Use two as split supplies with a very good dual C-L-C-L-C filter to take out the junk that Mooly noted.
A little close to the +/- 25V max for TDA2050 but you could add a few diodes for drop or add a linear (high current) regulator.
Or it might be easier to:
"A small 100 to 150va toroid and two moderate sized reservoir caps of say 3300uf to 6800uf would be ideal. Voltage rating to suit the chip you decide on. "
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 29th December 2012, 09:06 PM   #5
wahab is offline wahab  Algeria
Originally Posted by DUG View Post
OR
SMPS bricks have the negative pole connected to the earth
so putting two in series would yield a short circuit for the one
connected as negative PSU.
A solution is to remove the earth connection of the negative side
PSU since it will be forcibly connected to earth via its common
connexion with the other PSU.
That said , a genuine dual supply , SMPS or not, is a better option.
Old 30th December 2012, 02:57 AM   #6
Well, shiver me timbers, I did not know that.
So I checked out the six that I had in a box right beside me.
Four are as you say and have connections to the AC ground.
Two did not (only one is a two wire)
Learn something every day... thank you.
Old 30th December 2012, 03:30 AM   #7
Yes it would.
Newbie question - can I use my pc 24V 10A power supply for TDA2050 or LM3886 ampHide this!Advertise here!
Trouble Designing -/+12 & 24V power supply ZLyzen Power Supplies 43 22nd December 2011 11:00 PM
Simple TDA2050 mono amp for PC ToMiC Chip Amps 19 14th March 2011 11:04 PM
Which 24v dc power supply for T amp? dublin78 Power Supplies 1 16th May 2010 08:45 AM
12v -> 24v power supply mobyfab Power Supplies 19 8th March 2008 01:11 AM
Newbie Question, upgrade PC speaker's amp. Mikka Solid State 1 4th January 2003 02:23 PM
Copyright ©1999-2017 diyAudio
