HELP with LM3886 X3 in parallel.
The amps do function well as designed, but there is a rather detailed and involved process to match all the DC offsets. There is a good post about it and I will put it up when I find it. For now please look at this site.
This is the base design.
Since it has been mentioned twice on one page, it appears I need to revisit mine after buying some closely matched resistors. You can see in the picture I just used some generics purchased on eBay.
I'm not into chip amps at all but have an application where a pair in parallel might work well.
As far as DC offset goes I would build the amp, test it and make sure both amps work and the DC offset is say below 100mV to start. Then assuming the output short circuit protection actually works, I'd short the output and measure the voltage across the combining resistors as a measure of current, then trim the DC offset for minimum across those resistors. Then check it with the nominal load of 4 or 8 ohms, run it hard and check the voltage again hot to make sure it doesn't drift too much. Try this at your own risk of course.
I don't really like the high frequency compensation on these parallel amps, does anyone have the original Roland circuit, are people sure that this is the same circuit?
National show DC servos on the two channels that are to be paralleled.
I would start by ensuring that at switch on just as the mute unmutes that the unservoed offset is near zero mVdc. Then the servo takes over and tries to maintain that near zero mVdc offset as the chip warms up.
Doing that means the chips do not send current into each other, neither at start up nor as they warm up.
