Optimizing TDA7294 Output - Page 59 - diyAudio
Old 2nd May 2014, 08:02 AM   #581
Maybe we could use lower compensation with more gain
http://jimmy.thomas.free.fr/temp/TDA...93-MESURES.pdf
page 8 : 6X gain is stable without compensation
so it could be completely stable with a small compensation
Old 2nd May 2014, 11:15 AM   #582
dipolar is offline dipolar  India
dipolar's Avatar
Originally Posted by aparatusonitus View Post
No, you are right about gain...also note heavy RC compensation on input to make it stable for such a low gain.
I am wondering at the purpose of such a design ?
presumably low noise ?
3 mhz oscillation at 3.2x gain!
No act of kindness, no matter how small, is ever wasted.
Old 2nd May 2014, 11:39 AM   #583
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Lower distortion by virtue of greater NFB. Its only handling the bass freqs - there will be greater noise beyond the passband of the woofers by virtue of the RC network (4n7 - 2k2).
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 2nd May 2014, 12:46 PM   #584
Maybe it is not a 3,9X CR if R80 has an impact on the CR
39/((10*2,2)/(2,2+10)) = 21 ...
Old 2nd May 2014, 01:27 PM   #585
abraxalito's Avatar
At HF the effective input resistor is 1.8k (10k//2k2), giving noise gain X22.6. LF gain is around 4X as you've pointed out.
Old 6th May 2014, 08:07 AM   #586
danielwritesbac's Avatar
Originally Posted by UltimateX86 View Post
http://www.diyaudio.com/forums/attac...7293-hi-fi.gif
Hi Daniel,
what do you recommend as other changes in this diagram ?
Mute and STBY are optimal ?
In fact, what is the best TDA7293 diagram uncompromising ?
I do have a Parallel TDA7293 thread that produces an excellent 90 Watts for your very loud party.
However, there's no such thing as uncompromising with audio although there IS the possibility to fine tune per your particular usage.
If you want a lesser amount of compromise, see the SSA discrete amplifier projects (some odd 40 watts of high end sound--quite good!).
Or, if you want a loud blast of rather authentic concert sound (with a palatable tone to make that useful), see my mods in the TDA7293 Parallel thread. In either case, using them for what they're made for, yields best results.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 6th May 2014, 08:45 AM   #587
Originally Posted by still4given View Post
Sorry, not yet. I had another amp that needed my attention. I will try to get to it this week. As good as the one channel sounds this looks promising.
Blessings, Terry
Alternatively,
one may cut the gain and use the TDA7294 with a 13.5+13.5vac through 15vac+15vac transformer (anywhere in that range) and a 1u input cap. The low voltage allows decreasing the gain (and you should). Sometimes even the ill datasheet component values could even work. At the voltages that I mentioned 2k7+60k is "in the ballpark" for an optimal gain divider. One can use 220u cap (plus a suitable and/or crazy bypass) for inverting input coupler, and use 220u (or parallel 220u) for power decoupling. In this case of undervolting, you get the flea power mod, which is excellent unless you wanted to break ears and plaster. As described, it should run cool and stable and image very well.
By description, it seems that you have gotten some fake TDA7294's (the real thing hasn't been seen in many years, so that's not a surprise).
Version 6 ("V6") TDA7293 = old TDA7294 with advanced feature set enabled. Version 7 ("V7") TDA7293 = real TDA7293. Version 6 ("V6") TDA7294 = TDA2030A (lower voltage and lower gain, simultaneously). SO, if it behaves poorly, the power voltage (and gain) is probably far too high for what it actually is.
If your TDA7294 was made in March and version 6, then it is surely a fake, meaning that your power voltage is probably too high for the NEC UPC core (which is delightful, but is a low voltage piece).
Old 6th May 2014, 12:33 PM   #588
Cuda is offline Cuda  France
So V6 TDA7293 not good as V7 ?
Old 6th May 2014, 08:11 PM   #589
TDA7294 and TDA7293 printed with "V6" and "MAR" is highest probability of a fake. However, there are some authentic chips with that same marking and there's no way to tell by visual appearance. TDA7293's are easier to validate by the clip indicator pin, the predrive output and see if they work flawlessly in parallel without ballast. TDA7294's can't be checked any of those ways.
TDA7294 printed with an entirely numeric code and "SINGAPORE" is probably authentic (and old stock, made carefully, not last week).
Old 19th September 2014, 04:35 AM   #590
Cool got another fake!
made this , with fbstring : 68k - 2k2-100u100u047u ; 1uf input cap, 47uf bootstrap, 220uf power cap and 38 V rails unloaded, i tested with lamps in series it was ok then without...
it just made a tiny snap, like a match or something... and died!
its the second with 7293
OPtimizing the VBE MUltiplier fglabach Solid State 49 17th July 2016 07:58 AM
Optimizing active crossover atledreier Multi-Way 27 19th August 2011 02:53 PM
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 10:25 PM
Interesting linestage optimizing ideas PixelPlay Tubes / Valves 5 23rd June 2008 10:18 PM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 09:31 PM
Copyright 1999-2017 diyAudio
