Optimizing TDA7294 Output
Old 14th August 2013, 01:02 AM   #511
blakkshepeaudio is offline blakkshepeaudio  Australia
blakkshepeaudio's Avatar
Originally Posted by danielwritesbac View Post
>>> snipola
So I contacted Zoe Tsang (Not a financial affiliate) and requested this listing: Two board *stereo* kit TDA7293 Parallel amplifier
And I made this schematic.
And I made these assembly photos.
It is also in my signature line.
<<<< exit snipolito
Daniel,
Thanks for that clarification. I have bought a few fleabay amps over the years and board layouts have varied from good to appalling.
Nice to find a good one !
Kind regards,
Keith Arnold
blakkshepeaudio
Old 30th August 2013, 03:42 PM   #512
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default TDA7294
TDA7294 with dc protection
"It's Better to try and fail than to never know and always wonder"
Old 29th October 2013, 08:23 PM   #513
dipolar is offline dipolar  India
dipolar's Avatar
I wonder what they tried to achieve making this extra extensive layout.
ne5532 as dc servo ?
Ne5532 as voltage comparator for lm317..
What is that 470ohm, 0.5 ohm and 7.5k doing near the speaker ?
No act of kindness, no matter how small, is ever wasted.
Old 18th December 2013, 10:51 PM   #514
sghr220 is offline sghr220
Hi all,
Nice work Daniel and all who contributed to this great thread ...
I have one simple question about the schematic in post 461...
http://www.diyaudio.com/forums/attac...djustable2.gif
what is the purpose of the 220pF capacitor between the input pins? is it RF filtering? and what sonic effect does adding this capacitor have and the effect on the phase and magnitude of input signal like tyger23 mentioned in post 470?
Best regards.
Old 20th December 2013, 11:37 PM   #515
Another question...What is the voltage rating for the bootstrap capacitor?
Old 22nd December 2013, 12:51 PM   #516
Very useful guys thanks a lot
Old 23rd December 2013, 03:21 AM   #517
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by sghr220 View Post
I have one simple question about the schematic in post 461...http://www.diyaudio.com/forums/attac...djustable2.gif what is the purpose of the 220pF capacitor between the input pins? is it RF filtering?
It is to discourage RF. This is especially useful in the case of computers since would wouldn't want attempt amplifying the noise of a source that runs on extremely convoluted mess of a power circuit. Actually an inductor based filter would certainly work better, but it would not be so simple nor as inexpensive as the 220pF.
Testing input through output will show nothing other than you put in the cap, but this does not change any audible aspects of the amplifier. 330pF is also okay.
Although I loved the older production TDA7294, I absolutely hate the new production. So, unless you've got some new old stock sitting around, I'd recommend to avoid new TDA7294 new version craptastic waste of time. Instead of that, go with TDA7293's--those still sound a lot like they're supposed to.
50v, 63v, 83v, 100v are all suitable.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 23rd December 2013, 02:12 PM   #518
Spot-on Daniel thanks a lot for the detailed explanation.
Again you read my mind i have some NOS chips (to avoid the fakes) and a huge anodized heat all i need now is a good layout and i will give it a go. By the way i am going with your version named "TDA7294-Adjustable2" with some minor mods, I'll tell how it sounds as soon as i am finished.
Thanks and best regards.
Old 4th January 2014, 01:30 PM   #519
Guesstimation table for new production chips:
V7 TDA7293 = Real higher cost TDA7293
V6 TDA7293 = Real low cost TDA7294H (max 25+25vac transformer)
TDA7294 = TDA7295 or dirt cheap cull (terrible audio quality)
TDA7295 = TDA7295 or dirt cheap cull (terrible audio quality)
TDA7296 = Real TDA7296 OR a cheap substitute
This also affects authorized vendors. The ST chips that I have purchased from Mouser and Digikey have been identical to those in the eBay kits.
You really can buy an old-production quality TDA7294; but, it won't have "TDA7294" printed on the casing, AND all 15 pins will work.
Attempting to purchase TDA7296's sometimes works, and I guess that is because old stock of the less popular chip hasn't run out yet.
Old 4th January 2014, 04:05 PM   #520
My above post has an error. It is actually TDA7294S that has all 15 pins working. That chip is great. It can be labeled as TDA7293 in cheap kits. Sounds good, but has TDA7294's voltage and load maximums. If the whole kit costs less than TDA7293's, then I think that 25+25vac transformer is maximum. Otherwise, those things work great. They're a lot better than new production TDA7294's.
Sort of a made for a "big" sound arrangement. The adjustable gain is needed to find an ideal gain setting which varies by power voltage. The sweet spot isn't really findable with fixed resistor values.
One missing trick!
It needed a variable input load since 22k images better but with Louder Mids and 27k has softer pleasant mids. That probably needed to be a variable resistor for the slight fine tuning that could be done with it.
From years and years ago, here's an alternative: My old chip has 100k feedback, 2k7+220u feedback shunt, 36+36vdc rails (if you have less voltage likewise decrease the gain too), and is otherwise similar to the newer schematics. I like the lighter current at small signal area for its prettier midrange and treble and decent imaging; however, it is not as bassy. Both adjustable input load and the BlareBuster circuit can work with it, for relatively easy fine tuning of the input impedance that is and isn't.
P.S.
If you decided to separate the rails, protect the small signal voltage amplifier's power pins with MBR1645 schottky so that they can't go more than 1/3rd of a volt lower voltage than the output buffer's power pins. This approach is listed on some "hi fi version" schematics online but the chip breaks if lossy diodes are used for the safety bypass. SO, I suggest upgrading the BY fast silicon to MBR schottky on those separate rails schematics. I didn't publish any like that, because actually doing it right is more complicated than building a better discrete amp, and half measures don't outperform the simplified bus rail system shown on my schematics.
P.P.S.
These chips explode immediately if the bootstrap cap is backwards or a bad cap. Might want to give that thing a quick checkup before powering on. Or the easy way--a 33u Nichicon ES, which is good quality and never backwards.
Optimizing TDA7294 OutputHide this!Advertise here!
Optimizing the VBE Multiplier fglabach Solid State 54 27th December 2017 06:59 AM
Optimizing active crossover atledreier Multi-Way 27 19th August 2011 02:53 PM
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 10:25 PM
Interesting linestage optimizing ideas PixelPlay Tubes / Valves 5 23rd June 2008 10:18 PM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 09:31 PM
