Optimizing TDA7294 Output
Old 23rd February 2013, 01:52 AM   #341
simply14prem is offline simply14prem  Switzerland
when I turn off power one of the LED glows longer than the other,the other LED turn off instantly in my PSU,,is that a sign of illness in my psu ?.I think tda7294 needs a pre amp if played from a mobile hanset.
Old 23rd February 2013, 02:02 AM   #342
bcmbob is offline bcmbob  United States
Did you do the DIY power supply?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 23rd February 2013, 03:40 AM   #343
yes the same psu like you,how about you ,does the LED turn off instantly.
Old 23rd February 2013, 12:18 PM   #344
Both the PS and the amp LEDs on my build fade out. None of the four turn off instantly. The on-board LEDs are more sensitive and take longer but even they showed discharge after about 4 seconds . I did some timings this morning and found having just one amp with the new cap arrangement greatly influences the discharge time. The amp LED now fade first at ~ 4 -6 seconds. The modded amp side shows the presence of a charge up to 24 seconds. (on the PS only)
If you have two stock builds I would suggest swapping them to see if one of the amps is causing the discrepancy. A few posts back Daniel did remark he thought even my stock amp pair was a little slow discharging. Try the swap and let us know what you find.
Bob M.
Old 24th February 2013, 12:29 AM   #345
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Those times look appropriate but I'd need some more information.
It is important to compare when using the same model of speaker so that the load compared is the same.
Since the bass bandwidth is different between the two amplifiers, it is more useful to compare non-audio workload, and therefore we'd need to have the source connected, powered on, and the volume set to minimum (input dampening but no input signal).
In this condition, which amplifier takes longer to drain the power supply board?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 4th March 2013, 08:12 PM   #346
Default The next step. . . Optimize Pin 2
Parameters:
1). Feedback resistor within the range of: 25k to 110k
2). Feedback-shunt resistor within the range of: 1.3k to 3.0k
3). NFB-shunt cap sized to fit Feedback-shunt resistor value so we don't accidentally make a bass blur/blocker.
4). Gain settings within the range of 20x to 42x--Simply divide the two resistor values and then add 1, to find your gain value. Gain also affects compensation so be sure to observe temperature and aim for cool.
If you need some gain for either fun dynamics and/or so that a PC or digiplayer doesn't strain, here's a couple of possibilities.
75k with 2.2k for a gain of 35x or
60k with 1.8k for a gain of 34x.
In these two examples, the gain factor is nearly identical but the feedback current is different so the audio will be different (while driving a real speaker).
Choosing by observation:
Maximize the soundcast width of a single (mono) speaker, since the bigger presentation usually represents higher resolution of micro detail.
Maximize the baritone range clarity, especially Cello/Piano, because this is the harmonic range that allows you to hear bass in normal size rooms.
Those two audible parameters are adjusted mainly with these two resistors: Feedback resistor and Feedback-shunt resistor.
Old 6th March 2013, 02:09 AM   #347
I have played with gain of 24,32,40,50,60X but all of them are so weak and dull without a preamp.
Old 7th March 2013, 12:44 AM   #348
Fascinating! Is the source a tape head, phono cartridge, microphone or direct feed from a tuner? What music source do you have there?
Old 7th March 2013, 12:53 AM   #349
I'm feeling really bad/guilty.
I'm trying to finish up a couple other things and will get back to this effort soon. I'll probably move over to a breadboard format with pins to be able to try all the suggestions.
Bob M.
Old 7th March 2013, 08:57 AM   #350
Well there's just 5 things, some of which are location sensitive, so breadboard won't help. Just remember, you're also optimizing the sound of a given board. The easiest or fastest thing to do is actually use the printed circuit boards.
1. Feedback resistor trackside, onto the chip, from pin 2 to pin 14
2. Feedback-shunt resistor trackside (for easy swapping)
3. NFB-shunt caps and bypass caps mounted on pins (for easy swapping)
4. Input cap--mount helper/bypass cap trackside (for easy swapping)
5. Rail2Rail power filter cap (or RCR) at amp board V+, V- terminals
Suggestion: You've got a 2 amplifiers there, so modify whichever one you like the least, until it sounds superior. Well, the prospect is to mod one to beat the other, and then next, vice versa, round robin fashion, each better than before. Estimated timeframe when using printed board is from 2 to 6 hours depending on methodology with listening tests.
Optimizing TDA7294 OutputHide this!Advertise here!
Optimizing the VBE Multiplier fglabach Solid State 54 27th December 2017 07:59 AM
Optimizing active crossover atledreier Multi-Way 27 19th August 2011 03:53 PM
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 11:25 PM
Interesting linestage optimizing ideas PixelPlay Tubes / Valves 5 23rd June 2008 11:18 PM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 10:31 PM
