Optimizing TDA7294 Output
Old 8th February 2013, 05:48 PM   #311
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by bcmbob View Post
The power supply is excellent. The dynamics, punch, bass and stage all sound better.
Thanks for the review! And, congrats on the build!
There's no doubt that a power supply is an audio component.
You have presented several versions/designs - some with stacked resistors, cap count from 10 - 16 and different cap values. I used 3300 uF. Do you consider that the best choice? In keeping with the tread theme, which parts combination would you choose as "optimal" for this particular chip/kit? I have delayed my Mouser order to accommodate that info as well as the mods you listed in the last post. I will keep my "learner" PS build and start form scratch on a final.
It is quite likely that you already got it perfect and therefore I can't suggest any large changes. The series element could be made stronger by using several paralleled 3w metal film resistors instead of the single 5w resistor. And, with CRC power supplies, there is some sport in finding the perfect pi filter resistor value. http://www.sengpielaudio.com/calculator-paralresist.htm
This resistor value affects midrange tone, somewhat like the rail to rail filter, and both work by removing noise. *It might be easier to install the rail to rail filter at the amplifier board before choosing the CRC resistor value, if indeed one is out to find the perfect value.
If using 4 ohm speakers, you can change the 6a standard diodes (0.67v) over to series pairs of fast silicon diodes, such as FR or MUR, (0.45v+0.45v=0.9v) which will adapt the rail kicker action to fit the higher wattage amplifier and still meet AndrewT's "less than 1v" spec.
Installing Kean's secondaries snubbers should make the most important changes of all.
But, if you do want to build another supply differently, I might suggest to use the Nichicon FW 3300u caps. That and some black lacquer on the boards would make a beautiful black and gold show. The Nichicon FW have a better reputation for HF performance; however, you've increased HF performance of ordinary caps by 5x from paralleling them for lower loss, so I cannot tell you that upgrading the model of cap would make any difference. Therefore, I suggest a very real upgrade to 63v caps which can handle a wider variety of project voltages. That combination is here: UFW1J332MRD Nichicon | Mouser
(BTW, the PS dissipates quickly within 1-2 seconds.)
That's right when loaded with a pair of amplifiers that have the speakers connected (condition is loaded power supply And loaded amplifiers makes a fast drain).
However, 1-2 seconds is not quite right if that's the unloaded drain time. Do both sides drain at the same speed?
Also, though some claim no audible difference, would you recommend discrete PS units and/or transformers for the TDA7294?
We have an additional experiment to do, involving:
4 of MBR1045 (or similar MBR shottky diode)
and
either 4 of FB73 or two knots
The MBR diodes go in SERIES to V+ and V-, located at the DC input point at the edge of each amplifier board.
The cable knot or FB73's are located where the power cable goes into those diodes.
This mod cuts the crosstalk blur in half, so it is twice as effective as stereo but half as effective as monobloc/dualmono.
Traditionally, 4 regulators are used to create virtual dual mono, VDM; however, if one wanted unregulated VDM, then I propose it is possible to use schottky.
An alternative (slightly less favorable) location is to create a neat little daughtercard with the 4 FB73 and 4 MBR schottky that can plug into the output edge of the power supply board. It is series element (individualized per each amplifier), and MBR schottky has a miniscule voltage drop. This approach was previously drawn on my power supply schematics. So, if you go with the daughtercard approach, then you've got a dandy little dual mono adapter.
Advantages of VDM-Schottky:
♦ Does not complicate the grounding.
♦ Cost less than additional power supply for dual-mono.
♦ More efficient than regulators for virtural dual mono.
♦ If at the amplifier board, reduces DC cable length versus audio caveats (you can use thick and or short length cables if you want to).
Disadvantages:
♦ Because it didn't complicate the grounding, VDM-Schottky can't provide as much stereo separation boost as real monoblock/dualmono.
♦ Because of using only one transformer, one can't precisely constrain the current available to each amplifier. Compare: With a stereo build, each chip can have access to the full current output of the power supply (might be a "concern" with 4 ohm speakers); however, with real monoblocs, you could precisely choose the current available to each chip. So, with a real monoblock, it is unnecessary to give each chip access to twice as much current as it needs. For example, with the little LM1875 chip, the stereo builds break easily; however, LM1875 monoblocs with 1a transformers are very durable.
Sorry for the huge amount of text--the prospect is actually very simple and could probably be done faster than reading all that.
I couldn't find any information on the "Kean's" item. Will the Bourns trimmer work? Where do I put it and how do I use the variability aspect?
Keantoken's snubber dial. . .
You can install the variable RC's where you had previously installed the little green terminal blocks. That potentiometer works, but you can use a less expensive model if you want to. First you put its center pin onto either one of its outboard pins to create a varaible resistor. Next you put it series to a polyester cap of 1u or 2u or some similar figure. Now you have an RC--a variable RC. This is to snub the transformer secondaries. Variable RC = old fashioned tone control dial. In this case using it on the AC (transformer secondaries) side, muffles the power noise, not the audio.
With your voltage output reading (last time) indicating that one of the transformer secondaries is "louder" than the other, start on that side, with unloaded supply and the voltmeter hooked up. Set the snubber for lowest voltage, so that we're pretty sure it does something. It may vary only a volt, so an analogue meter might make more sensible readings. Next, dial in the other side for same voltage. After you have both equalized and lowered the noise powered voltage on both rails, that's "in the ballpark" and you can reconnect the amplifier and fine tune. This prospect may take some time. The settings are unique per each transformer.
This is like a top-secret audiophile thing where engineers will spend hours with their scopes. . . but Keantoken gave us a convenient and easy little dial to do that job. Awesome.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 8th February 2013, 06:22 PM   #312
Oops!
Should have been "several paralleled 3w Metal Oxide resistors"
This type: http://www.mouser.com/Passive-Compon...+oxide&FS=True
and
This: http://www.sengpielaudio.com/calculator-paralresist.htm
For a value within 0.22R to 0.39R range.
This approach creates a high wattage, non-inductive, resistor at low cost. And, without reliance on advertisements, it is truly non-inductive.
Caveat: You'll need to minimize pin length so it doesn't look like a fish net. It needs one big solid lead, not a bunch of small leads.
P.S.
The 0.24 ohm resistor that you already have, plus some pin length shown in the photos for approximately 0.27R is in the centerpoint of the applicable range. But, it is a 5w resistor and I know that you have a stereo build and some 4 ohm speakers, which is a high power application and probably needs a stronger wattage resistor of same value. Just upgrade the wattage rating.
Old 8th February 2013, 07:20 PM   #313
bcmbob is offline bcmbob  United States
O.K.
I'll digest everything from the last few posts, then repeat it back in bcmbobeeze to make sure I have it right.
be back a bit later.......
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 8th February 2013, 10:12 PM   #314
Since you haven't yet resolved the small signal bottleneck of the amplifier board then the only power supply improvements you could do at this time are:
♦ Definitely try Kean's variable RC's for snubbing the transformer secondaries.
♦ Possibly experiment with the VDM splitter for stereo width enhancement.
But, you need to postpone other tweaks until after the amplifier has been repaired to play full bandwidth, in order to avoid a round robin redo time consumption situation, that is bound to happen if we fixed the wrong spot first. So, with the bottleneck still in place, most tweaks will work like airing a flat tire up with Fix-A-Flat where you end up having to remove it before actually fixing the tire. Instead, we should probably try to fix the right spot first.
Old 9th February 2013, 06:30 PM   #315
Anyway, you did great with the power supply.
And that means. . .
Time to catch up on the amp board tweaks.
Old 11th February 2013, 10:34 AM   #316
Shaun is offline Shaun  South Africa
Shaun's Avatar
Delete post.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 11th February 2013, 12:01 PM   #317
FIY - Taking a few days away from DIY to work on some non-audio projects/commitments. Like Arnold ...I'll be back......
Bob M.
Old 11th February 2013, 04:32 PM   #318
Default VDM experiment
Virtual dual mono, VDM with schottky--cheaper than regulators, similar approach
Purpose = "crosstalk blocker" at less cost than dual mono.
Good part: MBRF1045-E3/45 Vishay Semiconductors | Mouser I like the insulated casing--safer than exposed tab, and MBRF1045 is a highly qualified low loss schottky. Conveniently, he can wear an FB73 ferrite as a bracelet for an easy way to add high quality power filtering.
Low cost part: SL44-E3/57T Vishay Semiconductors | Mouser A sturdy budget 8a schotty
VDM takes 4 low loss Schottky diodes, like this:
V+ Right channel
V- Right channel
V+ Left channel
V- Left channel
If it helps to make sense of it, use regulators instead, for the same stereo separation, crosstalk blocker, feature at higher cost. The schottky are far more efficient but don't provide regulated power.
P.S. Refer to KSTR's post #117 for more information.
Old 12th February 2013, 01:44 AM   #319
simply14prem is offline simply14prem  Switzerland
Im wondering what could be the specific driver requirements of Tda7294.I think it needs a good speakers. Im also confuse on what "maximum no of speaker outputs" is ?Does it mean like 3,4 speakers can be paralleled or with passive crossover.I need a tweeter ,,can anyone suggest me a good size,watt of it.
Old 12th February 2013, 05:11 AM   #320
Originally Posted by simply14prem View Post
I'm wondering what could be the specific driver requirements of Tda7294. I think it needs a good speakers. I'm also confuse on what "maximum no of speaker outputs" is?
One chip is rated to power One woofer of 6 or 8 ohms. For the rest of your question, here's a link to the speakers department of DIYaudio: Multi-Way - diyAudio
Optimizing TDA7294 OutputHide this!Advertise here!
Optimizing the VBE Multiplier fglabach Solid State 54 27th December 2017 06:59 AM
Optimizing active crossover atledreier Multi-Way 27 19th August 2011 02:53 PM
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 10:25 PM
Interesting linestage optimizing ideas PixelPlay Tubes / Valves 5 23rd June 2008 10:18 PM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 09:31 PM
