Optimizing TDA7294 Output
Old 13th January 2013, 06:14 AM   #201
keantoken is offline keantoken  United States
keantoken's Avatar
Gootee, let me try and make it more obvious that I am agreeing with you. A snubber has two critical parts right? A cap and a resistor? If either value is wrong the snubber ceases to perform its purpose. My cap is too small to snub the 14KHz resonance. After all caps DO snub. The difference is between snubbing and damping. It's a snubber and not a damper because it only damps resonances above the corner frequency. The cap's effect is to prevent damping frequencies that do not need damping, so that power is not wasted or linearity not compromised.
My damping resistor needs to be lower than 16R. How can I put this directly across the secondary without making a smelly heater or ozone destroyer?
BTW, thanks for the math info. I did not know that trick.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 13th January 2013, 11:16 AM   #202
Kean, I don't think you are agreeing with Gootee.
The capacitor does not act as the snubber of the oscillation.
The resistor dissipates the oscillation energy. The resistor is the snubber.
As Gootee and many others have said the capacitor is only there to reduce the dissipation in the snubbing resistor.
That dissipation could be due to both DC voltage and AC voltage. When significant resistor dissipation is due to the AC voltage, then using the method of Haggerman, or of Gootee, you can determine the capacitor value to minimise the resistor dissipation.
The capacitor is there only to minimise the dissipation in the snubbing resistor.
A little word, or several, of caution.
The esr of the capacitor will dissipate some energy. If the esr dissipation is significant, then you are risking overheating of the capacitor.
regards Andrew T.
Old 13th January 2013, 12:05 PM   #203
keantoken's Avatar
A snubber is two components, not just one. A snubber acts as dampening within the frequency range. Without a capacitor it would not be a snubber. I would not call a lone resistor a snubber any more than I would call a lone capacitor a snubber. Yes, the resistor dissipates the resonance. But that is only half of the snubber. Like I said, without the cap I would be making a smelly heater or a watt to heat converter. The cap is no more optional than the resistor. As far as I know, a snubber is universally known as a series RC network. No, the cap does not damp, rather it prevents damping. But it does snub.
Old 13th January 2013, 01:59 PM   #204
KSTR is offline KSTR  Germany
KSTR's Avatar
As long as we mean things the same way, it's only semantics how one calls it.
Still I'd prefer to stick to the common definition of a snubber as something that dissipates any out-of-band RF and spikes by applying a proper moderate resistive current path between two circuit points. This requires some resistance to act as the converter into heat, chosen to maximize the dissipation (drain away energy from the circuit). Since most often we have some wanted DC and LF content one needs the capacitor to isolate these signal components from the dirt, removing unwanted dissipation in the resistor.
Old 13th January 2013, 02:20 PM   #205
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by danielwritesbac View Post
Did you use more than 7 caps parallel?
Sorry I'm a bit slow to join the party here, but your mention of 7 caps makes me want to share a pic with you guys. I wire up 7 caps in a hexagonal arrangement. This works best with caps which are the tall, thin kind in terms of optimizing ESR and ESL.
Also here's a paper about how LTPs on opamps introduce distortion in the presence of RF - I know both Daniel and Jay have extolled the sonic benefits of singletons in chipamps, this paper gives a plausible reason as to why.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th January 2013, 02:32 PM   #206
bcmbob is offline bcmbob  United States
I have been doing a lot of reading on power supplies over the past few days, and now know enough to get myself in trouble (and a little embarrassed ) by asking semi-informed questions.
What primarily come to mind are the two approaches, on-board vs. discrete, placement of the PS. I ask this question based on the excellent results achieved in the MyRef designs. From my level of understanding, just the parts count alone (Daniel's latest PMed PS version is ~32 components) presents two widely divergent approaches.
I understand the goal is simply to feed the actual amp stage(s) the cleanest and most stable power, and we really appreciate the "first things first" path the thread is taking. But, again with reference to the MyRef results, and the following comment from KSTR:
"Further, I'm not a fan of fully independent mono-blocks (even when in the same chassis), so a complete stereo PCB with most of the supply components on board seems more adequate for most builders I would think. For DIY we also have the option to make use of unorthodox layout/component placement as we do not need to care about feasibilty for mass production (which means sticking to all SMT parts located on the same side)."
Has the optimal PS location/seperation been definitively agreed upon? That is not totally clear to me. Does this need any further discussion?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 13th January 2013, 07:33 PM   #207
keantoken's Avatar
The hexagonal cap bank is interesting. In this orientation the magnetic fields are aligned circularly like a toroid except for the center cap. I don't know whether this will improve magnetic interference but if the space around the cap has any effect on ESL than the effect here would be to increase it. I would orient the pins circularly instead of radially and connect the caps with twisted wires. This would minimize wiring inductance and the magnetic fields of the caps would cancel with them all facing inward (except again for the center cap).
I would think that the RF modulation effect would be worse for singleton frontends because they conduct better in one direction. I think it is misunderstanding the paper to say that it's just LTPs that suffer from this. An NTP (sibling of LTP) may have an advantage in that there is no parasitic capacitance to the rail at the summing point, but RF modulation may be worse because of the asymmetric conduction.
We can't know if we mean the same thing unless we get semantics right. There is no telepathy and guessing only leads to stumbling blocks. Without understanding each other we can only "agree to disagree" which is a crying shame when the problem is nothing but unclear semantics.
Old 13th January 2013, 08:01 PM   #208
KSTR's Avatar
Abraxalito,
thanks for the paper, nice to see some emprical data.
Bob,
Please keep in mind that the MyRef, being a nested amp with a seperate local low voltage supply for the master opamp, is a bit different that a standalone wrt supply issues.
At any rate I'm open to discussion. Basically I could imagine design a supply concept that is quite open to different options for everyone's likings, ranging from completely isolated mono-blocks la MyRef to the shared off-board main tank with only little local bypass. This kind of flexibility comes at a slightly higher cost (of the PCB, literally) and requires more design effort, in this case with the modified local bypass schemes and the series elements which are another playground for customization.
OTOH, now if there were some global preference for single-PCB mono-blocks here then let's zero in on those, perhaps with easy options for shared transformer (and diode bridges) to reduce cost/complexity for some builders.
Old 13th January 2013, 08:16 PM   #209
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Default Regulated front end, Nested, Composite & Howland (MyRef)
The MyRef apparently uses "regulated front end" model. The front end is the small signal op-amp. Regulated front end amplifiers can have power supply on same board as amplifier.
The series elements for the power supply of the MyRef front end power circuit are:
LM317, LM337. And the front end power caps are 100u.
(CQC, bigger voltage drop than CDC, but similar)
The series elements for the lm3886's onboard front end power circuit are:
PCB Traces, and then "re-stiffened" by 220u directly at the LM3886
(Mostly CLC, with a miniscule bit of CRC action)
Note:
Possible series elements include: Regulators, Transistors, Diodes, Resistors, Inductive cables, Inductors, and Inductive PCB Traces. And I propose that non-inductive or much less inductive series elements may be easier to control than inductor roulette. Since RF filtering turns up missing with non-inductive series elements, I proposed that the non-inductive series element (Regulators, Transistors, Diodes, Resistors) could be wearing an FB73 ferrite (or smaller) as a bracelet in order to restore/provide the filter function and still fairly predictable.
Large signal, high current area, Outputs:
It is usually pretty good to have some large capacitance available to the output devices for delivering bass impact. Caps for MyRef LM3886's output device power are 10,000u.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 13th January 2013, 08:18 PM   #210
Default When not using "regulated front end"
The TDA7294 PCB's from Ebay, have hardwired the output and front end power circuits together. Just remember that the cleaner power needs of the front end have not changed, and we shall be needing a series element followed by a cap that can charge very fast, such as 220u.
Unfortunately, the "simple" PCB has the outputs siphoning from the front end's power circuit, which is a compromise--the entire board is front end (small signal) power circuit. Like the LM1875 chip, the one and only large signal (entirely output specific) connection is: speaker ground.
An effective series element is not included with purchase of the TDA7294 PCB; however, it could be a cable from amplifier board to power board. This is "normal" but unfortunately cables are inductors, and quite like a tuner coil, really dodgy to get it just right.
I propose that a non-inductive series element (Regulators, Transistors, Diodes, Resistors) could be easier to use and a lot more consistent so that everyone could be "on the same page" rather than suffering inductor roulette.
In comparison to the MyRef:
The simpler TDA7294 board didn't remove complexity. Omitting functions doesn't accomplish that (unless one is willing to accept decreased performance). These (unfilled) needs and their normal complexity was merely relocated. And that location is dc cables, layout and power supply board.
Front end power circuit MyRef and TDA7294 PCB compared:
MyRef front end power circuit has regulators for series element, followed by 100u.
TDA7294 front end power circuit has cable for series element, followed by about 220u.
In this comparison, the TDA7294 front end power circuit is suffering from a poorer quality series element and suffering from a heavier load since the output devices are also using the front end power circuit and it needs clean power no matter how much load it is supporting. So, for the TDA7294 PCB, a finer quality power supply board could be helpful.
Optimizing TDA7294 OutputHide this!Advertise here!
Optimizing the VBE Multiplier fglabach Solid State 54 27th December 2017 07:59 AM
Optimizing active crossover atledreier Multi-Way 27 19th August 2011 03:53 PM
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 11:25 PM
Interesting linestage optimizing ideas PixelPlay Tubes / Valves 5 23rd June 2008 11:18 PM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 10:31 PM
