Current required for B1 buffer + chipamp
Old 23rd December 2012, 01:50 PM   #1
speleogen is offline speleogen  United States
Default Current required for B1 buffer + chipamp
Hi all:
I'm attempting my first DIY build with a LM3886 stereo kit from chipamp.com and a Pass B1 buffer. If I put them all in the same chassis, are there any problems with powering the B1 from the chipamp.com snubber board? I think the B1 draws on the order of 10's of milliamps which seems modest.
Thanks,
John
Old 23rd December 2012, 03:10 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Probably.
Personally, can't see the need to add a unity gain buffer between a 25K volume pot and a 100K chip amp input ... unless they are 1/4 mile away, of course (which does not seem to be the case) .
Old 23rd December 2012, 03:33 PM   #3
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
My DCB1 draws around 6W of power.
Gravity - Making the G since 13.7 billion B.C.
Old 23rd December 2012, 04:11 PM   #4
Originally Posted by JMFahey View Post
Probably.
Hmmmm . . . just assumed that an amp required a pre-amp. Noob mistake?
Old 23rd December 2012, 10:26 PM   #5
hates ground loops
Rodeodave's Avatar
Depends on what you are looking for. If you want to have a source selector, volume control, and couple of meters of interconnects, then yes, you need a preamp. But a B1 in the same box with a chipamp, which would literally be a unity gain buffer between a volume pot and a 100k (or so) input of a chipamp, makes little sense.
Current required for B1 buffer + chipampHide this!Advertise here!
B1 Buffer and some help please!!!! Malka07 Pass Labs 4 28th May 2012 07:18 PM
Pass B1 Buffer mantha3 Pass Labs 2 26th January 2012 11:35 PM
B1 buffer pmchoong Pass Labs 1 11th May 2009 05:48 AM
