OPA549 works in class B? or AB? - diyAudio
Old 22nd December 2012, 04:45 PM   #1
Default OPA549 works in class B? or AB?
is opa549 working in class B? i sometimes suspect as its application is more towards servo motors...
Old 22nd December 2012, 04:58 PM   #2
fooeywuffle's Avatar
Going by what little I could find, I think it has no bias at all on output transistors. I have made a few amps like that using discrete parts driven by an op amp and the results are bad. Harsh sound, and some crossover distortion.
Old 22nd December 2012, 05:18 PM   #3
Bone is offline Bone  United Kingdom
According to the data sheet, THD + noise, @1KHz with 25w into 4 ohms is 0.015% with a gain of 3. Quiescent current is between 26 & 35mA. So that doesn't appear to be Class B.
Old 22nd December 2012, 05:37 PM   #4
then can it be considered to be class AB?
Old 22nd December 2012, 07:55 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I'm quite certain it works in class AB.
A "regular" Op Amp has 2 or 3 mA idle current; this one has 26 to 35mA specified, well into what a discrete, class AB amp of similar power would use.
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright 1999-2017 diyAudio
