| Chip Amps Amplifiers based on integrated circuits |
Guys I need to make a DIY subwoofer amp.
I have seen original active subwoofers like Kenwood SW-900, SW-40 etc…They produced 70W RMS & 100W somewhat near sound. With that wattage you can shake your house. Also they don’t use bigger woofers, maximum they use 8” inch woofers to their designs. I need to make a subwoofer amp like that. My choices are LM3876, LM3886 & TDA7294. After a forum search I found that LM3876 sound quality is excellent. Is it enough for a subwoofer amp? I need advice from you what chip do you recommend? |
#2 |
Sound quality is not that much of an issue for a subwoofer. That is why you can buy plate amps and even complete active subs that are cheaper than a DIY chip amp.
How much power is enough depends on the woofer and your listening habits. Especially how low and loud it has to go. All three ICs you mentioned will be sufficient in more than 80 % of all cases. So if your case does not belong to the remaining 20 %, go for the one you like best of the three.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Hi thanks for your response.I can understand what you say.
Recently I made a subwoofer amp by using LM1875.No one worked with LM1875 as a sub amp & I noticed its output power is not enough for a subwoofer system. I hope I can hear a noticable change if I make a LM3876 based sub amp
#4 |
if your bass only speaker has a sensitivity in the >90dB/W @ 1m then 50W to 100W should be plenty for home use.
That puts the 1875 pretty close to being a good usable chipamp for bass only duty. However if you try to drive a 80dB/W @ 1m bass only speaker with 30 to 40W of maximum output power then you will be very disappointed. |
#5 |
Hi Andrew
Here is my woofer specifications its a Roadmaster RSW80 * 8" Pressed Aluminum Cone * 30 oz. Magnet * Rubber Surrounds * 200 Watts Total Instantaneous Peak Power * 40 watts Total RMS * 45 to 3500 Hz Frequency Response * Dual Voice Coil * fits a .75 to 1.5 CF sealed box * Push On Terminals |
#6 |
Does not help me.
Do they help you? |
#7 |
#8 |
You could use a parallel set of LM4780's to drive a dual voice coil subwoofer.
Each parallel LM4780 could deliver 120W per voice coil @ 4Ω and you could feed them from a single RCA input. |
#9 |
Sorry LM4780 is not available here.
All other ICs available here except LM4780 ![]() My goal is to drive a 8ohms subwoofer.For LM1875 also I series the two 4ohms voice coils & made 8 ohms
#10 |
Look up a design here on the forums for an LM3886 parallel design.
The LM4780 has 2 LM3886's onboard. 2 LM3886's actually are better at dissipating the heat since they have a greater surface area. If you will be running the sub in series 8Ω then you could bridge two 3886's and run them from an 18v secondary transformer. |
| chip amp recomendation | kentan | Chip Amps | 19 | 8th February 2012 11:13 PM |
| Subwoofer Recomendation | kctess5 | Subwoofers | 4 | 12th January 2012 09:47 PM |
| Chip amp for subwoofer | StalfoS | Chip Amps | 14 | 10th March 2007 07:18 AM |
| chip for a subwoofer amp (~20w)? | facundonu | Chip Amps | 15 | 14th November 2006 04:45 PM |
| chip recomendation for a bass guitar amp (already got a transformer). | facundonu | Chip Amps | 1 | 25th October 2006 06:55 PM |
