Output power facts - diyAudio
Old 14th December 2012, 11:02 AM   #1
regiregi22's Avatar
Default Output power facts
Hello,
Consider an LM3886 running at a trivial voltaje (in the operating range of course) at +/-35vdc rails. At worst case scenario, as datasheet states, accounting for chipamp losses, you will have +/-32 volts on the output at full power before clipping.
Then, ohm's law: P=V^2/R
So, peak output power at 8ohm should be 32*32/8 which equals 128watts
For a 4 ohm load, voltage should be +/-28vdc, so for a +/-25v output it is 25*25/4= 156watts.
How does it correlate to the IC datasheet, which specs 50watts at 8ohm and 68watts at 4 ohms?
Please try to explain that to me, as this is something simple that I cannot manage to understand
Thank you, best regards!
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 14th December 2012, 11:10 AM   #2
joram is offline joram  Belgium
Default peakvoltage vs RMS
32V is peak voltage.
If you would run a sinus with 32V peak you have to calculate the RMS voltage
32V / 1.414 = 22.63V
(22.63 x 22.63) / 8 = 64 W
25 V / 1.414 = 17.68V
(17.68 x 17.68) / 4 = 78W
Old 14th December 2012, 11:24 AM   #3
As the numbers above indicate, RMS is half your calculated peak power.
The supply in a real circuit will also droop, reducing the voltage swing.
rgds, sreten.
Old 14th December 2012, 12:27 PM   #4
Originally Posted by regiregi22 View Post
.............At worst case scenario, as datasheet states, accounting for chipamp losses, you will have +/-32 volts on the output at full power before clipping................
The 3886 datasheet gives guidance on what to expect for voltage drop through the amplifier when driving your 8r or 4r test load.
3Volts of amp drop is not the worst case value I would choose.
As Sreten mentioned, your +-35Vdc supply rail only holds that voltage while the amplifier is not delivering power to the load.
This supply voltage will drop when the amplifier delivers power to the load.
In addition the PSU has limited smoothing capacitance. As the current demanded by the load increases so does the ripple on the DC supply.
The droop in voltage due to the increased ripple must also be accounted for. Reading the average rail voltage while delivering full power does not account for the ripple. You need to measure the ripple separately and then subtract half that peak to peak ripple from the average reading that the DMM gave you.
In summary, the supply minimum voltage, at the power PINs, could drop to +-30Vdc from the unloaded +-35Vdc.
The volts drop through the amplifier could be 4V.
The maximum unclipped output voltage will be ~26Vpk for this example.
26Vpk converted to rms for the test sinewave will be 18.4Vac.
P = Vac*Vac/Rload = 18.4*18.4/8 = 42W into 8r0.
quite different from
equals 128watts
For a 4 ohm load, ............= 156watts.
regards Andrew T.
Sent from my desktop computer using a keyboard
Aleph Topology - Power Follower instead Common Source Power output ? tiefbassuebertr Pass Labs 1 26th June 2011 05:15 PM
SRRP Output stage. Calculating power output. Cassiel Tubes / Valves 1 1st March 2010 03:38 AM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 03:20 AM
Output power VS Peak output power Nordic Chip Amps 5 25th September 2005 06:08 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
Copyright 1999-2017 diyAudio
