LM1875 Single Supply Bandwidth - Page 2 - diyAudio
Old 11th December 2012, 11:59 PM   #11
Indeed. What is the input impedance of the 1875? I could not find it. It's probably low, but not that low. How about the tolerance on the input cap?
You can lower the low frequency cutoff by increasing the 1 uF capacitor if you like. Try a 2.2 uf cap instead. Are you using an electrolytic? You can get away with using an electrolytic input cap in a single supply amplifier. And you could beef up the "virtual ground" too with a bigger electrolytic (not too big) and a 0.1 uF cap in parallel with the electrolytic.
Old 12th December 2012, 12:43 AM   #12
What impedance dummy load did you use? 4 ohm gives -3dB of 18 Hz. This agrees with your measurements.
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
Effect of Supply noise on oscilloscope bandwidth? Craig405 Solid State 24 11th August 2009 08:50 PM
Lm1875, Single Or Dual Supply alcuemar Chip Amps 5 24th May 2006 03:02 PM
LM1875/lm1876 single supply? Adam M. Chip Amps 16 7th February 2005 02:06 PM
X Aleph Bandwidth & Power Supply macka2 Pass Labs 21 30th August 2004 04:08 AM
Copyright 1999-2017 diyAudio
