| Chip Amps Amplifiers based on integrated circuits |
Hallo everybody.
I am at my second adventure with chip amps. First one was a mono TDA7294 based machine that died for a mistake of mine. Now I took the same power section (+/- 40V and +/- 20V DC) and tried to assemble a mono bridge LM3886. It worked for 5 seconds and then started giving a white noise through. So I shut down for a while, noted that the chips were pretty warm, and turned on again. Same story. All of this was accompanied by bumps at switch on and off. I suspect something on the mute pin 8, but oscillations on the pre-amplification stage could be the cause as well. Any hint anout this? Thank to anybody who may help. Hallo again. I found that the cause of the white noise was the LM318 I was using as a signal amplifier. I had it connected with 10kohm on the inverting input and 75kohm on as feedback (gain should be -7,5) and powered with +20V 0V leads. Bypassing the LM318 no noise went through. Using 220uF caps on the pins 7-8 of the 3886's I had the bumps deleted. Now the points are: 1- I am using a 0-50 kohm potentiometer for volume (took it from a broken down Sherwood ampli). I cannot get the volume to 0 neither shortcircuiting the signal to its GND. Any ideas why? 2- I cannot reach a very powerful output: the toroidal transformer is rated 110VA and the LM3886 in bridge configuration should yield at least 50W on 8ohm. My Proton AM2 is much louder, and it's a 50W on 8ohm. Any ideas? Thank you. Last edited by NWE; 15th January 2013 at 11:45 AM. Reason: More info |
| White Noise Generator | LAJ | Equipment & Tools | 15 | 31st March 2012 12:25 PM |
| White noise problem | Kei | Solid State | 4 | 1st February 2012 07:35 PM |
| White Noise Active PSU | ANDYLASER | Swap Meet | 5 | 12th January 2009 06:37 AM |
| White Noise, Protruding woofer | Code | Class D | 6 | 16th January 2008 06:02 PM |
| HELP: White or Pink noise problem | Tedyp | Parts | 2 | 26th March 2006 10:42 PM |
