| Chip Amps Amplifiers based on integrated circuits |
#11 |
I notice a lot of consumer gear operate the transformer partly into saturation. Dropping the frequency will cause this to be more of an issue. Keep tabs on the temps and be sure it isn't getting to hot.
#12 |
Normally it *should* not be a problem.
This is confirmed by the freezing cold temperatures shown by that transformer. As a side note, I live in 220V 50Hz Argentina, we are chock full of US amps "bought in Miami, NY or LA", US version (as in 120V_only windings / 60Hz) and that has never been a problem. Besides, Korean stuff is usually very well made. That transformer looks good. |
#13 |
Operating temperature is a very good indication of abuse, whether due to voltage or frequency.
Check it often and learn to "read" the abuse or not. You may be OK. There is an alternative: But you need to be confident that you have the skill to do this safely. Add extra primary turns ! Even as few a 20Turns makes a significant difference to the idle current. You can measure the primary idle current with care to avoid electrocution ! |
#14 | |
Owner and operator of irc.tenettenba.info
I'm surprised no one has asked you if you can measure the unloaded transformer voltages and give us an indication of its open circuit readings... Then its dc resistance taken when all secondary windings are disconnected from the amp pcb... Its probably because that is an enviable rats nest in there, and finding a substitue transformer for it would be next to impossible without a lot of head scratching... ------------------------------------------------------- Option #1: The only way I see out of this problem is to keep the transformer cooled with the fan that you've got there, possibly making a second power supply inside of the case specifically for the fan, or simply volt regulating it with a L200 vreg board off ebay and tapping into one of the AC windings which is within the range of the input voltage of the LM317... http://www.ebay.com.au/itm/LM317-Adj...#ht_3595wt_689 Then turning the trimpot on the LM317 vreg board down so that the fan doesn't stall but keeps silent..Probably around 7-9v DC. ------------------------------------------------------- Option #2: This to me seems like the cheapest way out, but if the OP doesn't have confidence to do mains wiring then I suggest a different approach, and that is to simply get a power supply plug pack and a couple of chassis plugs and mount the fan inside of the case, then mount the chassis plugs and use the external power supply to keep the fan running. I don't see any harm in letting the transformer run with a fan pointed in its general direction, does anyone else? I of course don't take any responsibility for loss of life or injury or damage to equipment, household or family if the OP or anyone else takes my advice and that by reading the above post and or this legal disclaimer that you agree to abide by these terms.
| 230 50hz-120v 60hz | flatheadmurre | Power Supplies | 0 | 15th September 2011 08:22 AM |
| Converting 50Hz to 60Hz??? | Antripodean | Parts | 26 | 18th April 2009 07:39 AM |
| Linn 50hz to 60hz? | protos | Analogue Source | 3 | 24th June 2005 07:35 PM |
| 50hz on 60hz | lawbadman | Power Supplies | 10 | 21st April 2005 01:26 AM |
