LM1875 Maximum Gain
LM1875 Maximum Gain
Old 10th December 2012, 06:45 AM   #11
pra3718 is offline pra3718  India
actually this is too loud for a room,& you can shake the room
@Joseph1, Is this your first thread & post ? I am not going to disappoint you, but LM1875 is not too good for subwoofer. or you are cheated. So I would request you to build LM1875x2 / LM1876x1 + LM3886x1.
Elektro Jiwaku: Hi End Home Theater 2.1
Or, Build 2.0 Bi-amp.
Best Regards.
Old 10th December 2012, 08:45 AM   #12
Joseph1 is offline Joseph1  Sri Lanka
Hi pra thanks for the link.Do you have any schematic of it?
Old 10th December 2012, 08:57 AM   #13
The silk-screen is there in provided link. You should read and understand whether it is fit to your requirements or not. This is just for idea of 2.1. What is your planning ? Let me know.
Old 11th December 2012, 11:23 PM   #14
Ok.After I completed making my LM1875 2.1 system I'm going to build a stereo amp using two TDA7294.
Actually I already made this LM1875 & all I need to do is fine tune to get maximum performance from it.
I have a problem.I need to measure my source outputs sensitivity or input sensitivity.
This is the procedure.
Play a track on the MP3 player & hook an oscilloscope on the output of the MP3 player.Read the peak value shown on the oscilloscope.
Is this correct?Do we use peak values or rms values to determine input sensitivity?
Old 12th December 2012, 10:45 AM   #15
no.
record a constant voltage sinewave to a medium that your source can replay.
This sinewave should be related to the maximum that the medium can record.
say you record a 0dBfs signal, then the output of the player will be at full scale.
If you record at -6dBfs then the output of the player will be at half the maximum.
Pano did a file for a pair of -9dBfs signals in his what power Thread.
regards Andrew T.
Old 12th December 2012, 11:07 AM   #16
R.I.P.
Overall gain is too high to match well with a normal amplifier (high pass
filtered with a cap on its input) well. There is no reason to use S&K
type filters with their intrinsic gain, use a unity gain topology.
rgds, sreten.
Old 12th December 2012, 11:13 AM   #17
or MFB filters where the gain can be selected.
regards Andrew T.
Old 12th December 2012, 11:23 AM   #18
Hi Andrew thanks
Please don't angry with me I'm new to this decibel figures.I cannot understand decibal stuff.
I actually don't know how to send a 0dB signal & -6dB signals.
Old 12th December 2012, 02:24 PM   #19
rgds, sreten.
Your point also good.
LM1875 gain = 22.6
pre amp (Filter) gain = 12.1
Supply voltage = 25V dc
My overall gain is = 22.6 X 12.1 =273
Its pretty big but the sound level is nice as a professional subwoofer system.Also with 250mV input sensitivity I can volume it to maximum level.
What you mean by unity gain topology?
Preamp = sallenkey filter + gain stage
You mean disconnect gain stage & leave only sallen key part & feed to LM1875 amp?
LM1875 Maximum GainHide this!Advertise here!
Gain Lm3886 = Lm1875 nek antunes Chip Amps 2 2nd August 2012 02:36 PM
solar maximum scott17 Everything Else 16 1st February 2012 11:54 PM
RENKFORCE E-SA9: A Commercial Gain Clone Integrated Amp with LM1875 ?? tiefbassuebertr Chip Amps 0 25th January 2011 09:41 PM
Maximum gain with 6SN7 ? Gwaltinger Tubes / Valves 16 6th December 2009 12:44 AM
minimum gain for LM1875 Leolabs Chip Amps 3 14th November 2006 02:53 AM
