LM3875 Inverted Or Not? LM3875 Inverted Or Not? - diyAudio
Old 8th December 2012, 02:16 PM   #1
tom wesley is offline tom wesley  United Kingdom
tom wesley's Avatar
Default LM3875 Inverted Or Not?
Im thinking of building a valve buffered clone. Does it have to be an inverted setup? Am i over/under complicating things. Is non inverted possible?
British Dept. for Unlikely Audio.
Old 8th December 2012, 02:25 PM   #2
I get the impression you don't know what you are doing.
Post a schematic and hope that someone can guide you.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th December 2012, 02:28 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You can take a peek at my project but the design isn't set yet and not explained. This will come later on. The schematics will also have variants.
My project is a single/dual E88CC tube buffer in cathode follower mode or "White Cathode Follower" mode + inverted/non-inverted gainclone (LM3886) + power supply.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 8th December 2012, 02:33 PM   #4
tom wesley's Avatar
I understand the schematic in so far as ive built gainclones (non inverting kit) and wondered if i could builb a valve buffer for it. The schematics are all a variation on inverted designs. I dont fully understand the implications of using the valve with the chip
Old 8th December 2012, 05:58 PM   #5
peranders's Avatar
You will get a rather low input impedance of the inverting amp so a buffer could be good to have and why not a tube buffer in order to get some tube flavored sound.
Old 8th December 2012, 06:11 PM   #6
tom wesley's Avatar
But is it feasible to do with non inverting amp?
Old 8th December 2012, 06:53 PM   #7
Robert Kesh is offline Robert Kesh  Wallis & Futuna
Robert Kesh's Avatar
yes, though no longer as necessary to have a buffer. you would just do it for colour.
perhaps people only use inverting to justify using a buffer to themselves, and hence valves.
Old 8th December 2012, 07:06 PM   #8
KSTR is offline KSTR  Germany
KSTR's Avatar
Unless you have whimp of a preamp, inverted config doesn't necessarily need a pre. You can get pretty high input impedance (like 10k) when using a T-network for the feeback path.
Old 8th December 2012, 08:45 PM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Thorsten Loesch's design -- one of the originally published gainclones -- is inverted. The inverted version includes everything "before" it in the feedback loop so a buffer is really required. Buffered, inverted gainclones, in my experience, are best of breed. If using a cathode follwer, for best performance requires a CCS on the tail of the CF.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th December 2012, 09:21 AM   #10
madtecchy is offline madtecchy  England
I have tried the t network on my inverting lm3886. The extra connection to ground seems to inject ground noise into the input... Any comments?
Ps can get 10k input impedance without t network in inverted mode
LM3875 Inverted Or Not?Hide this!Advertise here!
Look for tube buffer for inverted LM3875 Mrpong Chip Amps 7 26th July 2006 08:18 AM
lm3875 inverted layout with 100k pot, not enough volume? rocktboy Chip Amps 11 12th January 2006 05:44 PM
Non-Inverted Gainclone PCB layout (LM3875) BrianGT Solid State 17 15th April 2004 04:30 AM
LM3875 Inverted Layout Comments Please ppereira Chip Amps 43 4th November 2003 10:46 PM
Copyright ©1999-2017 diyAudio
