LM3875 Inverted Or Not? - Page 2 - diyAudio
Old 9th December 2012, 12:02 PM   #11
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by madtecchy View Post
I have tried the t network on my inverting lm3886. The extra connection to ground seems to inject ground noise into the input... Any comments?
Looks like layout/wiring issues, not a conceptual problem. T-network has a slight noise penalty in general, though. And higher than unity gain at DC with either only input coupling capacitor or T-network cap (in the GND leg).
Ps can get 10k input impedance without t network in inverted mode
Yes, that means 100k++ feedback resistor which is a bit too high for my tastes. More important is that any inverting confic should have a capacitive feedback divider (to GND rather than -Input), too, to keep it stable with open or high-Z input termination.
Old 9th December 2012, 12:55 PM   #12
Could either of you post typical schematic to show what your are referring to?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th December 2012, 06:11 PM   #13
tom wesley's Avatar
Thanks for the help guys. Thats answered my question...
British Dept. for Unlikely Audio.
Old 9th December 2012, 06:11 PM   #14
KSTR's Avatar
Inverting amp with T feedback network
Old 9th December 2012, 06:30 PM   #15
KSTR..
I use a computer and an external dac.. I tried the T network on an already built and in service inverting lm3886. I had no issues with it at all. I read about the t net feedback idea and i gave it a try as it is simple to implement . and with the t network computer noise is audiable.. I have no stability issues with just a single feedback resistor . 220k
Old 9th December 2012, 06:41 PM   #16
KSTR's Avatar
If it's runng OK (also in terms of offset) with 220k that's fine. But what happens if you happen leave the input open circuit? Unless you've taken measures against it you'd have unity gain then and the circuit would most certainly oscillate.
Old 9th December 2012, 06:53 PM   #17
In my case leaving the input open circuit is not an issue as it is hard wired to the dac. The dac is buffered after the volume pot so the offset stays the same with diffrent volume settings too. The dac is not a diy unit.. i have had the lid off and done a little looking about i couldnt resist... KSTR you have raised some very good points and also given the solutions .. If i where to build a standalone amplifier i would implement them.
Old 9th December 2012, 07:09 PM   #18
KSTR's Avatar
That's simply because I'm in the (slow) process of designing an inverting nested/composite chipamp where stability at all working conditions is the paramount issue.
Look for tube buffer for inverted LM3875 Mrpong Chip Amps 7 26th July 2006 09:18 AM
lm3875 inverted layout with 100k pot, not enough volume? rocktboy Chip Amps 11 12th January 2006 06:44 PM
Non-Inverted Gainclone PCB layout (LM3875) BrianGT Solid State 17 15th April 2004 05:30 AM
LM3875 Inverted Layout Comments Please ppereira Chip Amps 43 4th November 2003 11:46 PM
Copyright 1999-2017 diyAudio
