lm386 heatsinks
The LM386 is not a good choice for bridging. Current drive is so limited with it that power folds up quite a bit under load.
Here's a list of IC output power using a regulated 9v supply. The power is continuous sine wave before clipping into non inductive loads.
As you can see, some ICs can practically double the output of the LM386 with 4 ohm loads.
thanks :D in the end its just an expiriment lol but that table helps
Let me add the Chipamp I use commercially: TBA820M .
I searched a lot and it's the best one available when the supply is 9V.
And it keeps working down to 3V, so *very* dead batteries still provide *some* sound to save a boring night, until shops open in the morning.
From its datasheet:
Output power: Po = 2W at 12V/8r , 1.6W at 9V/4r
and 1.2W at 9V/8r.
www.kolumbus.fi/mikko.esala/d/tba820.pdf
Can be bridged for incredible 3.2W RMS into 8r out of a 9V supply.
I downloaded the tba820 datasheet, thinking it would be useful.
Now that I have read said datasheet, I have not saved it. The performance is dreadful.
minimum distortion ~1/3 of a percent.
0.5% distortion at 1/2W
noise -70dB ref 1.2W
I wonder if it is a ClassB output stage to save battery power?
This is an ancient chip. It needs a lot of external components to make it work including external frequency compensation (not common on modern low power audio amp ICs). Distortion isn't really that bad. I doubt it could swing any better than 2.25 Vrms into an 8 ohm load @ 9v Vs. Some tube nuts would say a 35C5 SE tube amp, with a few percent distortion at best, would sound better.
¿Dreadful?? 1/3 of 1% ??? -70dB noise??? :confused:
Get REAL folks, it's a chip designed for 9V battery portable stuff. :rolleyes:
Leave cork sniffing to those guys who can justify it.
As in 30Kg PSU Class A with no feedback and such.
Yes, it has exactly 4 (four) extra components, compared to, say, an LM1875 or TDA20xx , those being:
1 and 2 ) a bootstraped resistor and capacitor , which by design swing *beyond* the 9V rail for full drive.
A more "modern" and linear Constant Current source, from a PNP transistor hanging from said rail, will *lose* the CE saturation voltage, and in *no way* will swing above it.
3) an external compensation capacitor, which is *good* because it lets you get stability at widely different closed loop gains, while many chipamps can not go below, say, 15dB because they start oscillating.:eek:
4) an (optional) ripple compensation capacitor, for those who want to increase ripple rejection. At least now you have the option. ;)
Precisely that's the point: to use efficiently up to the last tenth of a volt (which is the precious commodity here), they added some external bootstrapping ... big deal.:D
But of course, it's the end user decision.
If he prefers to lose 25% power to lower distortion from 0.3% to 0.003% , that's his choice.
In any case, what I see is that when my TBA820 starts clipping, "the others" are supplying a nice squarewave struggling to reach same power. ;)
And then, how much distortion we have?
Just sayin' :hohoho:
Of course, anybody can use whatever he wants.
Including paper in oil caps, silver wire wound transformers, cryogenically treated tubes and wool from Woolly mammoths cabinet damping.
Why not?
