LM3886 at very low load < = ohm - Page 2 - diyAudio
Old 6th December 2012, 07:07 PM   #11
Mooly's Avatar
This is what my version of the data sheet says,
Supply Voltage |V+| + |V−| 20V to 84V
So thats -/+10 to -/+ 42 volts.
Old 6th December 2012, 07:53 PM   #12
There are some TDA7293 kits available on ebay that have 7 parallel TDA7293 chips.
if one chip can drive 4 ohm, 2 chips can drive 2 ohm, 4 chips can drive 1 ohm etc. They are inexpensive.
Assembled DIY Power Audio AMP 7*TDA7293 Parallel 555W Mono HiFi Amplifier Board | eBay
Old 6th December 2012, 07:55 PM   #13
Originally Posted by AndrewT View Post
+-10V as a minimum, is met by your two 12V car batteries.
But you must ensure that the chipamp does not drop out if the voltage AT THE PINs droops to near 10V. I think one pin has a cut out set to ~ 9V.
I was planning to use a ridiciously large cap bank... Have atleast 50 000 uF per rail.
Worst case I will increase supply voltage a few volts. As I wrote, I have cooling capacity to spare.
listen! Can you hear that ...
Old 7th December 2012, 12:29 AM   #14
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Well, your real limiting parameter is Peak current capability, which I don't remember now but I guess it should be way over 4 Amps.
TDA20xx and such hover between 3.5A and almost 4.5A
What does the datasheet say?
Old 7th December 2012, 11:14 AM   #15
Min 7,5 amps, typical 11 amps so it should be fine.
Old 7th December 2012, 11:17 AM   #16
but only when "cold"
Tc=25degC is specified in the datasheet.
That limit will decrease with increase in chip temperature (Tj).
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th December 2012, 12:55 PM   #17
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
I have been using LM3886 with loads which drop to less < 1 Ohm at certain frequencies. In some cases as low as 0.5 Ohm.
Supply voltage +/- 32V.
The amp is very likely to work normally until the point where the chip is overloaded then SPIKE protection kicks in. That means output voltage is limited.
It will not self destruct normally(although it is doable when you bridge the chips and run at very low load impedance).
Hope this helps,
Lukas.
Old 7th December 2012, 03:17 PM   #18
Originally Posted by Bazukaz View Post
..................(although it is doable when you bridge the chips and run at very low load impedance)...............
did you mean to type "bridge"?
Or should it show "parallel"?
regards Andrew T.
Reasons LT regulator fails under load Brouilly Power Supplies 48 29th November 2012 07:32 PM
Is Aleph 2 unstable < 6 Ohm??? Thago Pass Labs 4 13th July 2007 10:29 PM
LM3886 gain clone vs STK4048XI for 4 ohm load filgor Chip Amps 0 25th September 2004 12:05 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Need something stable into <8 ohm loads Jean Solid State 7 25th September 2003 11:05 AM
Copyright 1999-2017 diyAudio
