Please help - Chipamp lm3886 amp blowing fuses
Old 4th December 2012, 10:17 AM   #11
basi is offline basi  Croatia
basi's Avatar
Becasue T version must be isolated from Heatsink if Heatsink is grounded.
Ako imaš tf verziju onda dobro postoji ona plastična izolacija već na njemu.Pozdrav i sretno.
Less is more!!!
Old 4th December 2012, 10:18 AM   #12
sofaspud is offline sofaspud  United States
sofaspud's Avatar
It's hard for me to visualize exactly what you had connected, but it sounds like the short was far ahead of the amps so they should be okay. Here's hoping.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th December 2012, 01:15 PM   #13
R.I.P.
Originally Posted by iggy111 View Post
Ahhh, for Christ sake...
In my hurry to get the amp working, I forgot there is a difference between a CENTER TAP and DUAL SECONDARIES trafo.
Yup, I hooked up a CT trafo to both rectifier bridges by connecting its GND to both...
Now I'm going to try to connect it as in this pic, hoping I didn't fry the amps:
Let the young ones learn from this (he said knowingly)
Once again, the mains bulb tester would have prevented this mishap getting through !!!!!!!
Another unhelpful post of mine, because Members won't read.
regards Andrew T.
Old 4th December 2012, 01:22 PM   #14
iggy111 is offline iggy111  Croatia
And it's working ))
So I removed the 4 diodes and hooked up everything as in the pic, and now it works. Still have to solder the inputs and outputs again before I test it with some cheap speakers...
@AndrewT - you're right, but I was too anxious to get it going that the bulb tester seemed like another project Will DEFINITELY build it before any other project! I swear!
Old 4th December 2012, 05:06 PM   #15
Ok, so just to finish this topic and move on - my amp now works fine, the problem was in using center tap (CT) trafo and not doing the necessary changes in the psu. The fuses kept blowing but luckily nothing else was damaged.
After the changes (desoldering the 4 diodes and connecting the trafo differently) everything works fine. Tested with speakers and all
Please help - Chipamp lm3886 amp blowing fusesHide this!Advertise here!
LM3886 amp started blowing fuses. Where do I start? bluegti Chip Amps 14 1st June 2009 02:31 PM
Help with blown Fuses LM3886, Chipamp.com schmalex Chip Amps 21 23rd November 2006 02:23 PM
