| Chip Amps Amplifiers based on integrated circuits |
#11 |
Heat transfer is better without the pads and as my H/S is a 3/4 Lb gold plated brass bar and electrically active it is isolated and is on a nylon suspension inside the cab.
ron |
#12 |
hmmm...maybe you should try aluminium oxide as an insulator...seriously...I mean it's just crazy to use metal to insulate...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#13 | |
the thermal "cost" of insulation can be calculated explicitly, and is part of the three theta's. i don't see why it's a problem . |
#14 |
The gold plated brass bar is more than insulation its also the H/S.Heat transfer is greatest when you have 2 surfaces that are flat to each other( //) to within .0001". They then wring( believe thats how its spelled, its not ring) together (actually stick together without any grease).As all i use is the LM3875T version that means the bar is electrically active so i just isolate the bar.Worked very well so far with 12 different GCs.Of course i use a poly (looking at Cu though) pressure bar for clamping.
Both the block and the chip are surfaced on a granite inspection plate that is accurate to within .00001" using a plate polishing compound. ron |
#15 |
Yeah...good idea...but then again...if you go through so much...might as well just insulate the whole heasink and make sure it does not touch the chassis...or at least get the isolated version...
jackinnj: I was saying that the ISOLATED version (TF) does NOT need an insulating pad...but the non-isolated version needs (T) guess must be different interpretations of my above posts...
#16 |
Yea the gold plated brass bar is suspended by a poly plate and nylon bolts(brass on some config). It more or less just hangs from the roof of the cab.
ron http://community.webtv.net/roncla/PressureLoadingBar I am using my couch potato link as i am still trying to figure out windows 2000. |
#17 | |
#18 | |
#19 |
I'm not so sure....I just use the isolated version on my GC...makes it all so easy...I guess you can try out RS...Farnell or SLT (Sim Lim Tower) have seen insulating stuff there...but not sure if they are Aluminium Oxide though...
#20 |
Digi-Key has silpads in the MultiWatt format which means LM38xx size.
UrSv Those who say it can't be done should not stop those who are doing it. |
| Insulating coatings | arend-jan | Planars & Exotics | 19 | 17th September 2009 07:54 PM |
| PCB insulating lacquer? | mozilla | Parts | 3 | 20th September 2005 11:42 PM |
| insulating silver wire | amisdad | Chip Amps | 17 | 5th October 2004 11:30 PM |
| Insulating TO-264 packages | mbroker | Parts | 5 | 13th December 2002 04:50 AM |
| Page generated in 0.25760 seconds (100.00% PHP - 0% MySQL) with 9 queries |
