Troublesome Technics SA-310
Old 1st December 2012, 02:55 PM   #1
Jtpython is offline Jtpython
Default Troublesome Technics SA-310
Hello, I am new to this forum, the other day I was using my Technics SA-310 and when I turned it on the speakers on the right side made a short buzz and then stopped producing sound all together. The left side still works, but it seems to me that the power is a bit reduced. Any advice as to what is wrong and how to go about fixing it would be greatly appreciated!
Old 1st December 2012, 06:23 PM   #2
stratus46 is offline stratus46  United States
Lower cost Technics often used power hybrid modules (early 'chipamps'). I think you'll find yours has failed. If you repair it yourself beware of failing solder connections of the heatsink mounted components to the PCB. BTW don't run it until it's repaired.
G
Old 1st December 2012, 07:05 PM   #3
So you're suggestion would be to replace the STK module?
Old 2nd December 2012, 08:48 AM   #4
Being a tech I'd do some testing on it but in all likelihood that will do it. It's fixed if you can put the problem back.
G
Old 2nd December 2012, 02:22 PM   #5
Could the root of the problem be the pre-drive or the current stabilizer transistors?
Old 3rd December 2012, 08:49 AM   #6
Most common electronic failures are the devices that run hot. The Voltage regulators are common to both channels so nothing would work. The pre-drive is often an opamp and while they fail, it's a rarity. I'm just going on the odds here so it could be something else but power devices are by far the most common.
G
Troublesome Technics SA-310Hide this!Advertise here!
Technics sa-5400xc Ravens45 Solid State 0 10th February 2012 02:15 PM
Technics SA-G9057 vcard717 Solid State 0 7th January 2008 02:27 AM
Technics SA-310 won't make sound tonyroma Chip Amps 8 23rd May 2006 01:11 PM
Troubleshooting Technics SA-310 DcibeL Chip Amps 6 26th August 2004 09:50 PM
