| Chip Amps Amplifiers based on integrated circuits |
Trying to figure out which of these would give the best sound (ignore the price):
LM3886 68Wx2 HiFi Audio Amplifier SRH-19 - Boards | Kits | Components | Modules | Tools LM3886 Amplifier Kit | Chipamp.com Any hints? Other suggestions? |
#2 |
seeing as they both use the same chip they probably sound pretty similar , sorta like comparing apples to apples .......
#3 |
Maybe try the Audiosector LM4780 Dual Parallel kit.
That is what I'm currently building and I ran it in stereo for a while and really liked it. |
#4 | |
LM's chips are good, but if you look for better sound, Go discrete!!! ![]() My first amp was the Lm3875 from Audiosector, it sounded good but some members here told me to try discrete amps and I did. My first discrete amp was the NXV200 from Aussie amplifier (very good) and after that I try many others from diferent companies. I know one thing... I am not going back to the gainclones for sure!!!
#5 |
Here is a little blurb I did in response to a similar question.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#6 |
The idea of Best Sound could mean anything.
The most malleable chip that is also easy and very clear is the LM1875, with excellent odds of getting the sound you want. It is a simple op-amp (not polluted by extra features), there's a lot of designs for it, and it is rather easy to fine tune it to do whatever sound you like. Every time you double the amp power, you get just 3db more from the speaker, which is not a very significant change. So, if 25 watts per channel isn't loud enough, then a very few decibels more from 60 watts won't be impressive either. Therefore, if you're looking for high power, hi-fi in a chip, go for an LME chip.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#7 |
Awesome replies. Thanks!
| A-B-C comparison, Chipamp, MyRef C and Anthem Integrated 225 | Noseehum | Chip Amps | 11 | 10th May 2012 09:53 AM |
| Comparison of sub drivers | Vivek | Subwoofers | 5 | 6th January 2009 10:50 AM |
| Tweeter Comparison | lewisd | Multi-Way | 8 | 6th April 2007 03:56 AM |
| Tweeter comparison | DSP_Geek | Multi-Way | 2 | 11th January 2005 03:11 AM |
