TDA7294 all in one
TDA7294 all in one
Old 24th December 2012, 01:34 AM   #11
SERGIODS is offline SERGIODS  Peru
Originally Posted by gev View Post
TDA7294, vumeter, tone control and DC rectification filter all in one single PCB (pcb program proteus ares)
test video; TDA7294 Komple 100W Amplifikatör Vu Metre Ton Kontrol - YouTube
PCB desing: Ahmet YERLİ
armastes already.
Old 24th December 2012, 08:50 PM   #12
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by SERGIODS View Post
armastes [translation: "big mess"] already.
Consider that this particular power op-amp will run better if set to low gain.
If the tone amp section can provide some gain, and if the TDA7294 is switched over to hi-fi design instead of datasheet example, then the tone amp is not reducing system quality. It is, perhaps, a "break-even" prospect. This idea could be upgraded to hi-fi if a "tone cancel/bypass" switch were added to allow the preamp to be used without the tone processing.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 9th June 2013, 03:54 PM   #13
LazaKamikaza is offline LazaKamikaza  Serbia
If I don't want the VU-Meter, what parts can I not have on the board, and what rated transformer would I need for the whole thing? Thanks
Last edited by LazaKamikaza; 9th June 2013 at 04:18 PM. Reason: I forgot to add something
Old 11th June 2013, 04:36 AM   #14
Default check
You better check it, but it's like that
TDA7294 all in oneHide this!Advertise here!
Tda7294 again .!! PROFESSOUR2003 Chip Amps 8 2nd February 2011 10:07 PM
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
problem with tda7294 Chaom1 Chip Amps 7 6th January 2006 12:33 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
