LM1876 Mute by Voltage divider.
Old 9th December 2012, 10:05 AM   #21
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I measure the voltage at power supply. 22(+/-)VDC correctly supplied to Power-amp but Regulator 7818 is not supplying +18VDC DMM shows below <1 vdc WHY ? I could not understand.
You should separate the power supply from the amp and figure out why you aren't getting regulated output. I can't tell anything from the pic and schematic. Are you sure the switch isn't defective?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 9th December 2012, 10:44 AM   #22
pra3718 is offline pra3718  India
you are requested to view lm1876.pdf in post #12 (please ignore if seen)
Yes, Today I will try this.
Old 9th December 2012, 10:50 AM   #23
At first time, Regulator 7818 is not supplying +18VDC and 2nd time (OFF/ON) shows +18VDC. Very confusing.
"Life isn't qualified by the branded clothes I wear or fluency of my english. It's measured by the number of faces who smile when they read my post."
Old 9th December 2012, 11:59 AM   #24
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Try a (reversed) diode across 7818/ 7918 in/out. 1N400x type
Old 9th December 2012, 12:11 PM   #25
If I understood correctly, I was thinking the same. Thank you very much.
Power Supply for Preamps
Old 9th December 2012, 01:00 PM   #26
I also think the problem arose when you added the 5v regulator. Is'nt it?
You do not really need that regulator. A zenner and a resistor would do it.
Old 9th December 2012, 01:41 PM   #27
This is another helpful post...# 26
What I will do is.. First I will remove 5v regulator, then try what shows 18V regulator.
If 18V regulator works correctly with several ON/OFF then 5V Zenner will be use.
If 18V regulator does not work correctly then try for (reversed) diode across 7818/ 7918 in/out
After all 5V zenner and resistor is good idea.
Thank you bobodioulasso, you have provided good information for my home-work, Please give me time for trial.
LM1876 Mute by Voltage divider.Hide this!Advertise here!
LM1876 Mute & Stand-by pra3718 Chip Amps 14 23rd November 2012 02:59 PM
voltage divider merlin el mago Tubes / Valves 8 9th October 2012 11:28 AM
Voltage divider? fatmarley Solid State 40 18th April 2012 11:10 AM
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 05:28 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 05:19 PM
