Help! Need usb powered Amp. - Page 2 - diyAudio
Old 25th November 2012, 07:57 AM   #11
panson_hk's Avatar
Take a look of this one http://www.hi-wave.com/downloads/dat...IAM-USB213.pdf
Old 25th November 2012, 10:54 AM   #12
looks like
DyadUSB is based on the AS2002, highly power efficient, switching, stereo audio power amplifier from Audium Semiconductor,
is using the 5V from the USB to create a +-9Vdc supply to drive a bridged amplifier (4 channels for stereo). That would expalin the preference for 16ohms to 8ohms speaker recommendation.
But
2x 13W peak power output (8ohms)
may really be 6.5W into 8ohms.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th November 2012, 11:17 AM   #13
panson_hk's Avatar
The chip (AS2002) has a boost converter for maximum ~21 V high-rail voltage. It can therefore deliver higher peak power. This is similar to a boosted Class D.
Old 25th November 2012, 11:24 AM   #14
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by AndrewT View Post
looks like is using the 5V from the USB to create a +-9Vdc supply to drive a bridged amplifier (4 channels for stereo). That would expalin the preference for 16ohms to 8ohms speaker recommendation.
But may really be 6.5W into 8ohms.
i'm sorry, but how on earth does a convertor make 6.5W out of a 2.5W supply? they should patent that quickly!! surely you can only increase the voltage at the loss of current, overall power should remain the same minus losses from the convertor
Old 25th November 2012, 11:41 AM   #15
The pdf states that average music power is many times lower than maximum output power.
I happen agree with this statement.
If they designed for an average to peak ratio of 20dB (130mWpeak from a 13Wpeak) amplifier and used a very efficient DC to DC converter to create the supply rails and used a very efficient switching amplifier then it is very possible that the 500mApeak supply @ 5V could maintain the average levels required and capacitor storage can then supply the peak power for the high current transients.
The pdf does state
DyadUSB is a USB powered stereo audio amplifier module; designed to be embedded in to USB speaker systems.
and that implies they are designing to suit the limitations imposed by the USB power.
regards Andrew T.
Old 25th November 2012, 11:56 AM   #16
panson_hk's Avatar
The chip is designed for high crest factor signal, music, instead of sine wave. It can deliver high short-term power, but low average power. It uses "big" reservoir caps at boosted high rails.
The board is available at RS http://hongkong01.rs-online.com/web/...ivers/7616037/.
Old 25th November 2012, 12:25 PM   #17
sofaspud's Avatar
I cannot find anymore that accept the analog signal from the headphone jack which is what I need because the Xbox does not produce a digital audio signal through usb.
LM386, TDA7052, etc. run on 5V @ <500mA and are designed to drive small speakers and headphones. They use simple-to-build circuits that accept an analog input.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
USB powered DAC + Amp Recommendations seander77 Headphone Systems 5 2nd April 2012 07:39 PM
Self-powered USB DAC/Headphone Amp combo? mr_push_pull PC Based 4 20th May 2010 08:48 PM
class d usb powered amp? pekar Class D 6 10th September 2007 06:37 PM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 07:11 AM
USB powered HIFI headphone amp/DAC Benjlv Headphone Systems 13 9th January 2004 04:04 AM
Copyright 1999-2017 diyAudio
