is it possible to bias opa627 into class A?
Old 23rd November 2012, 04:59 PM   #1
rhythmsandy is offline rhythmsandy
Default is it possible to bias opa627 into class A?
i have a pair of opa627 very impressed with its highfreq performance and would like to make this chip work in class A.. is it possible did somebody do this before how about stability and performance and heat issues...
Old 23rd November 2012, 05:13 PM   #2
jcx is offline jcx  United States
Class A depends on load - for driving a 50 kOhm volume pot most op amp outputs factory internal bias already is Class A
so you really have to know the signal, load - and the limits of the op amp - many may additionally distort from current drain that is even a modest fraction of their rated output
careful meausurement of actual op amp with load is needed to see if, or by how much you are improving distortion - often a 2x THD reduction is all that is found
2 op amps can be paralleled, biased "against each other" in push-pull, of course with significant Class A current bias you have to deal with the heat:
Opamp based Amps - Question
I like multiloop composite circuits - use the OPA627 as the input and global feedback stage around a 2nd op amp with much higher current specs - easiest to compensate with a really fast output op amp - like a CFA - TPA6120/THS6012 is great for line driving, most dynamic headphones:
http://www.diyaudio.com/forums/solid...-circuits.html
is it possible to bias opa627 into class A?Hide this!Advertise here!
Class B auto bias mchambin Solid State 6 1st March 2012 06:59 PM
High bias class D sendler Class D 42 18th September 2010 01:41 PM
RCD-965BX / OPA627 - Class A Bias & O/P Coupling Caps poozebear Digital Source 6 13th July 2007 11:59 PM
OPA627 in class A - swap to 134 or 604? Zombie Solid State 3 26th January 2005 11:15 AM
lm6172 class a bias? crippledchicken Parts 0 3rd September 2004 05:33 AM
