Old 5th April 2004, 01:27 AM   #181
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Thank you,Though sound very magical , I will try it
Old 5th April 2004, 02:03 AM   #182
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by Nuuk
50 volt rating I hope if he is being safe!
Digi, were you asking about the caps because they are silver? If so, this is achieved by skinning the caps, ie taking off their plastic jackets. Some people claim that this changes the sound although I cannot hear any difference but it does make them look nicer.
It is indeed 35 V and the best deal that came from Indonesia on BG caps. Not available anymore. I will not be using more than 24 V on rails (from batteries) so it it safe.
I think I observed a slight difference when skinning coupling caps ( a bit more of somewhat unrestricted sound)), but it is nothing to rave about. I skin them mostly to avoid soldering burns on the plastic jacket
Old 5th April 2004, 06:04 AM   #183
digi01's Avatar
Thank your patient reply peter.
Have you tested the battery power supply? If use the battery, may cancel two capacitors?
I feel a great interest in discussing the battery supply power problem such as charge, structure...etc too.
Old 22nd June 2005, 06:37 AM   #184
Smith88 is offline Smith88  Australia
Send a message via AIM to Smith88 Send a message via MSN to Smith88 Send a message via Yahoo to Smith88
Default transformer coupled IGC
Would it be possible to use a transformer to couple the input of a 3875 in the Thorsten IGC circuit to a 6sn7 (or any DHT for that matter) instead of the 4.7u cap and 10k resistor.(im thinking the transformer would reduce the bandwith to the chip, keeping it stable and blocking DC and optimum impediances could be chosen for the 3875 and 6sn7 to work into)
Has anybody done something like this before?
I think it would be Beneficial to get the cap out of the signal path.
if this is possible id like to directly couple it to the output of a 6sn7 line stage.
any help appreciated.
Thanks.
Trying to improve on an Input Chooser concept Peter Daniel Chip Amps 62 25th February 2004 03:55 AM
Page generated in 0.16052 seconds (43.55% PHP - 56.45% MySQL) with 11 queries
