Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) - Page 5 - diyAudio
Old 23rd November 2012, 07:13 PM   #41
keantoken's Avatar
That line looks smooth, but distortion is relevant in the 1/100 and up range, you cannot assess that visually on a scope. Actually I think I can see some Gm doubling there, it straightens out the sine curve near the crossover region so it looks more triangular.
Furthermore, say your VAS input has an impedance of 500k which is normal. Your miller cap is virtually multiplied by the voltage gain of your VAS, so your VAS gain rolloff corner is probably in the tens to hundreds of Hz. So for most of the audio band into RF, your input stage sees not what is in your scope shots, but that through a +6db/octave frequency filter. So the reality is worse. In LTSpice, you can plot this by entering D(R5) and you will probably see the crossover distortion now. Now you can compare it to an EF.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 23rd November 2012, 07:21 PM   #42
bigwill is offline bigwill  United Kingdom
keantoken,
The signal is across that 1k resistor that feeds the VAS buffer, which is after where the miller cap feeds back to the LTP - the voltage at that point would look very lowpassed I'm sure, since it's a current node, but this resistor should reflect to some degree the current being fed into the VAS transistor, I think?
I'm not speaking with any authority on this, I'm by no means an expert in solid state design.
Old 23rd November 2012, 07:21 PM   #43
AndrewT is online now AndrewT  Scotland
Bigwill,
how are you attaching your pics?
I can't see anything.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd November 2012, 07:24 PM   #44
Originally Posted by AndrewT View Post
Bigwill,
They're hosted on a popular image host - peculiar that they wont show for you - perhaps their domain isn't resolving for you?
I'll attach them directly to my post if necessary..
Old 23rd November 2012, 07:27 PM   #45
Here they are attached to diyaudio. It should be obvious which one is which
Old 23rd November 2012, 07:40 PM   #46
I can see these.
It will be my PC security blocking remote servers that are on an "avoid" list.
regards Andrew T.
Old 23rd November 2012, 07:42 PM   #47
Mooly's Avatar
Originally Posted by bigwill View Post
Note that the funny notches on the peaks of the sine wave are from the signal generator.
That's a common effect caused by synthesizing a triangular wave (that function generators produce as a base waveform) into a sine wave.
Installing and using LTspice IV. From beginner to advanced.
Old 23rd November 2012, 07:44 PM   #48
why is the lower leg of the NFB taken to the -ve rail, rather than to the source return wire?
regards Andrew T.
Old 23rd November 2012, 07:47 PM   #49
I used an electrolytic cap here - I just wanted to ensure it was charged to the correct polarity. I've always suspected there is a better way of doing this though!
Old 23rd November 2012, 07:51 PM   #50
the -ve rail will inject all the rail rubbish into the -IN pin and it will get amplified to come out of the OUT PIN.
regards Andrew T.
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 07:49 AM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 09:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 07:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 08:05 PM
Copyright 1999-2017 diyAudio
