Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)
Old 25th November 2012, 10:14 PM   #81
bigwill is offline bigwill  United Kingdom
It just occurred to me - under current swings the collector voltage on the driver transistors will be around 0.6v from the rail due to the base of the output transistor. If the VAS tries to pull the driver base higher than this, the driver obviously can't accommodate for this fact, can't turn on the output transistor any harder and becomes saturated.
The feedback diode seems to reduce this enough to stop the rail sticking, but doesn't cure the clipping spikes. An interesting problem though!
Old 25th November 2012, 11:00 PM   #82
keantoken is offline keantoken  United States
keantoken's Avatar
Try a schottkey diode if you haven't. At +V clipping there should not be a current spike through R5, this means Q5 is saturating. If Q5 saturates, negative feedback becomes positive and the amplifier latches until the input swings enough the other direction to reset the LTP.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th November 2012, 09:26 AM   #83
Hi keantoken, I tried the diode first of all and it worked very well - I just happened to discover the other issues while probing around.
Regarding Q5 saturating - I'm not quite with you about this reversing the direction of the gain. Q11 can only pull 10s of milliamps through the base due to R5 - even at these high base currents, I don't see how the VAS voltage can fall. The current is going through the Vbe diode and Q5 is switched on as hard as it can. The output stage is already clipping at this point, so even if the gain was reversed somehow, we're already effectively in open loop conditions.
Old 26th November 2012, 09:39 AM   #84
I could see this happening with an emitter resistor in the VAS, but the only resistance is the inherent emitter resistance of the transistor, which is probably way too small to have this effect, and rise enough voltage to 'un-clip' the output stage to cause positive feedback
Old 26th November 2012, 01:54 PM   #85
keantoken's Avatar
It does not matter how much gain there is as long as it is reversed. If it reverses, it's positive feedback period. It will cause the circuit to latch. Q11 may be limited by R5 but until that point readily saturates Q5.
What do the spikes look like? Those TIPs are super-slow and clunky, they are probably complaining very loudly when saturating. You might try probing R8 and R15.
Old 26th November 2012, 02:52 PM   #86
The issue actually appears to be the current mirror on the LTP - if I replaced it with the usual collector resistor, the sticking vanished, even with the VAS transistor still driven heavily into saturation.
Old 26th November 2012, 02:59 PM   #87
keantoken's Avatar
That makes sense. Remember the VAS gain corner is probably in the 100s of Hz. This means the miller cap is effectively huge compared to the impedance at the VAS input. Therefore if this cap gets charged due to a glitch, it will take a long time before it can discharge and reset the circuit. Getting rid of the current mirror drastically lowers VAS input impedance.
This is one of the reasons I don't like large miller caps. One thing you can do if you think distortion is already good enough, is to degenerate the input stage in order to make the miller cap smaller. Furthermore, I believe you can also lower the miller cap if you trade the outputs for an MJE1503x pair which will be faster and cause less second-order loading of the frontend.
Old 26th November 2012, 03:51 PM   #88
The diode from VAS output to buffer input works great, but I'm going crazy trying to figure out WHY it works. Without it, the current mirror goes unbalanced during the sticking period, but with it, it feeds some current into the input side LTP. This brings the current mirror back into balance, somehow.
Old 26th November 2012, 04:53 PM   #89
keantoken's Avatar
Interesting. Sometimes current mirrors are misapplied so that Q9 will saturate, but that is for the negative excursion and doesn't seem to apply here. Also, current mirrors in this position need transistors with good quasi-sat curves. BC5xx and BC3x7 are good. 2N5550 and 5400 are often used here but really shouldn't. The datasheets don't show Vcesat behavior for the 2N390x.
What is the Vbe mismatch between Q10 and Q9? It will suffice to probe between the emitters with a DMM while the amp is running with no input. Despite the 56R degen the CM will unbalance at very low currents, even if it is not saturating, as a result of any significant Vbe mismatch. But current should only get this low during clipping. How much does the current mirror unbalance?
Old 26th November 2012, 05:18 PM   #90
This has all been in simulation BTW.
Weirdly enough, it doesn't seem to be a drive issue. During the sticking period, the VAS driver abruptly stops feeding the base, until the voltage drops back within the rails, yet the VAS stays on for a period of about 4 microseconds. If I change the VAS transistor to a BC557, the rail sticking stops, even without a diode.
Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)Hide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 07:05 PM
