Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)
Old 15th January 2013, 03:28 PM   #191
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by keantoken View Post
If we knew the thermal resistance to ambient of the altoids tin we could calculate our minimum bias. I would stand the tin up on its side with vertical vents, this way convection is maximized, and more surface area is in contact with the air.
the 1.76 oz (50g) Altoids tin has a surface area of over 17 inches! Sides included. Output devices should thus be placed on the bath-tub portion of the tin.
I placed a 6 ohm 50W dale resistor in the tin, thermal goo and attached via 4-40 screws. cooked it for 10 minutes @1.4A:
Temperature rise after 10 minutes was all over the place -- from almost 65 degrees at the lip end of the cover to 40 degrees (C) where the cover is attached to the bath-tub. Thus you could fry an egg on this thing.
Old 15th January 2013, 03:51 PM   #192
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Wow !!
THANKS a lot for making this IMPORTANT experiment !!!
I didn't build mine yet, those pesky customers who demand what they've pre-paid for keep me busy!!!
But it sort of confirms my idea of adding a small CPU type fan .
That *besides* my original idea of pop riveting an aluminum rectangle to the case bottom, with thermal paste in between, of course.
Thin tin by itself is a very poor thermal spreader.
Just curious: what was the temperature just over the resistor?
Because what you mentioned ("lips" , "cover", is some distance away).
Old 15th January 2013, 04:05 PM   #193
keantoken is offline keantoken  United States
keantoken's Avatar
So thermal resistance is somewhere around 3.2C/W. Very useful to know, thanks! Do you know the ambient temperature at the time of the test?
So it would take ~47W to fry a silicon output device at 150C. Although the lytics would be long gone by this time.
Lets identify the max internal temperature tolerable for preserving the lifespan of the components. Then we'll know how much we can dissipate in this tin with reasonable longevity.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 15th January 2013, 05:01 PM   #194
jackinnj's Avatar
Thermal rise was 65 degrees -- it's a little warm in the workshop in the winter as the furnace is nearby -- so it started at 25 and ran up to 90. I think it can be improved by using a bit of 1/8" aluminum stock.
I will use lateral mosfets, lower over-head means less heating, no necessity of source resistors.
Old 15th January 2013, 05:10 PM   #195
keantoken's Avatar
So that's actually 5.5C/W, corresponding to about 27W at 150C.
Old 15th January 2013, 05:25 PM   #196
jackinnj's Avatar
And that's about what i calculated prior to the experiment just using the surface area of the tin. It will be too hot to pick up or hold in your hand.
Old 15th January 2013, 06:48 PM   #197
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
The tin could be seen as a cooling tunnel into which an airflow would be forced.
Holes for in holes for out, both ends.
Old 17th January 2013, 11:34 PM   #198
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Lower cost versions of lateral mosfet include Power Mosfet and under-volted TDA7296.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 18th January 2013, 07:25 AM   #199
bigwill is offline bigwill  United Kingdom
Hi everyone,
I am still alive. Bear with me, I have been rather busy
Old 19th January 2013, 02:06 PM   #200
jackinnj's Avatar
Plenty of room:
The substrate is 3/16 aluminum and fits into an altoids tin.
Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)Hide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 07:05 PM
Copyright ©1999-2017 diyAudio
