Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)
Old 3rd January 2013, 05:25 PM   #181
Tekko is offline Tekko
Banned
Most likely TDA2030/LM1875
Old 3rd January 2013, 10:11 PM   #182
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Mint tin, Office Depot, Walgreens, have the old fashioned size mint tins like mine that will even fit an STK chip, as shown in post #6.
Thanks, but I'm in Buenos Aires, some 8000 miles away
Problem is, up to a short time ago dollar/toy shops were full of nice tin cases in all sizes and shapes (printed with Barbie/Hello Kitty/etc. graphics for young girls), now I can't find them anywhere, shop owners inform me "they are out of fashion" and try to sell me the current (plastic) ones.
So far I have secured 3 tin cans which approximately fit the specs:
1) a round tin ashtray, 3 3/4" diameter by 1 1/2" high. Of course it has a round cover
2) a rectangular tin (Winnie the Pooh graphics) pencil case, 8" x 2 1/4" x 3/4" (if no better found, I'll use this one)
3) a sardine can, emptied by yours truly, 2 1/2" x 4 1/4" x 1" which also looks promising.
It does not have a cover, of course, which was cut away with a tin can opener , but I can fashion one out of some aluminum sheet.
Which is good because it's a better heatsink than paper thin tin.
Well, if by the end of the week I don't get a better one, I'll use one of these.
Stay tuned
Old 3rd January 2013, 10:41 PM   #183
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
These are car air fresheners:
Click the image to open in full size.Click the image to open in full size.
Maybe they're at the auto parts store or that sort of department in a larger store?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 3rd January 2013, 11:02 PM   #184
JMFahey's Avatar
I'll check.
So far my favorite is the pencil box, just checked my standard 2200uFx50V radials fit very well , I think 4700x25 are about same size, so I might either make a monoblock LM3886 40/50W amp or stereo 2 x TDA2050 .
I might even fit a flat CPU fan inside , for forced cooling.
This is slowly taking form in my mind.
Just don't want to rush until I have the physical space defined.
The actual electronics part is a piece of cake.
PS:you hit the nail right in the head, with the "Hello Kitty" can
Old 3rd January 2013, 11:21 PM   #185
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
So how much does it cost to send the poor guy and Altoids can?
Old 3rd January 2013, 11:27 PM   #186
JMFahey's Avatar
Probably much more than the project is worth
Don't worry, I haven't been yet to Downtown.
Where I'll probably buy an actual Altoids (o Cadbury/Riggs or any other) can, and empty its contents .... although my Doctor will frown on that.
Don't worry, we're almost there.
This is for Fun, anyway
Old 3rd January 2013, 11:38 PM   #187
You hit it on the head, go to one of the high end candy stores and they will usually have tins of sours or fruit flavored hard candy. It seemed that for awhile you couldn't go anywhere and not see an Altoids tin of some sort of strong mint.
Old 4th January 2013, 09:38 AM   #188
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Probably $3 airmail from the US if its empty
Old 4th January 2013, 10:44 AM   #189
JMFahey's Avatar
Hey !! , why *empty*???
You sound like my Doc/wife/daughter
Anyway, don't worry, I've settled on the Winnie the Pooh pencil box, being rectangular but most important, flat bottomed, allows me to pop rivet an aluminum rectangle as heat sink, thermally coupled with some grease.
Now, where did I put those TDA2050?
I'll build it this weekend.
Old 4th January 2013, 12:24 PM   #190
Originally Posted by JMFahey View Post
I'll check. So far my favorite is the pencil box, just checked my standard 2200uFx50V radials fit very well , I think 4700x25 are about same size, so I might either make a monoblock LM3886 40/50W amp or stereo 2 x TDA2050. I might even fit a flat CPU fan inside, for forced cooling.
This is slowly taking form in my mind. Just don't want to rush until I have the physical space defined. The actual electronics part is a piece of cake.
I've got some ideas for you.
With a discrete amp possibly in the lead at the moment, you might want to get a bit competitive with a "made for compact stereo" chip amp. That compact stereo class of chip amplifiers feature generally cooler running and audibly level harmonic response that makes component selection and fidelity much easier to do.
The monobloc option is either a parallel amp or has parallel output devices (same number of output devices and same minimum total system power as the stereo build).
Instead of a fan demonstrating that inefficiency has required forced air cooling, you might consider a cool running amplifier, feet on the bottom of the enclosure, passive intake vents through the bottom of the enclosure (vents underneath caps and also vents at heatsink/spreader materials), and passive output vents at near the top of the enclosure. It is also possible to use metal feet with a bit of rubber on the bottom.
Good power and other filtering and compensations all to restrict the amplifier to "only audio work" can make it run quite cool by increasing the efficiency of its primary task, which is only audio. Datasheets list some "optional" rf filtering and you can check to see what will make your amp run cooler. This is a linear amplifier efficiency contest.
You hit the nail right in the head, with the "Hello Kitty" can
Would be so very surprising for Hello Kitty mint tin amp to output exuberant hi-fi. Really fun to show it to friends and neighbors just to see their expressions.
Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)Hide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 07:05 PM
