Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)
Old 27th November 2012, 04:40 PM   #111
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
So, who's going to do a class AaH or AaG amplifier with some fets? That's the state of the art in cellular transmitter amplifiers and if applied to audio, it could, perhaps make Class D look outdated.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 27th November 2012, 04:51 PM   #112
bigwill is online now bigwill  United Kingdom
I've had another play with the circuit in real life - I tried both EF outputs and CFP. I think I prefer the performance of the CFP. One thing is the superior bias stability, which is likely needed when your heatsink is a tin of golden virginia
I'm getting some parasitic oscillations but the circuit is a mess of wires and jumpers on a breadboard. Next week I will have time to etch a PCB and see how the circuit really performs. I will test it with the TIPs and see what the actual measured performance is like. I will post harmonic spectra.
This is not to say I haven't taken aboard the recommendations for better output transistors, I just want to see how well the TIPs will actually work in real life. A 100W amplifier I repaired in real life seems to achieve rather good performance with "glacial" 1Mhz Ft output transistors.
Old 27th November 2012, 04:51 PM   #113
keantoken is offline keantoken  United States
keantoken's Avatar
You are going to confuse people by referring to glitching as noise.
When you go totally without bias, you not only have transistor glitches to worry about, but the current spike induced by the error voltage. On miller compensated amps this will be monstrous. It will be near impossible to achieve low distortion this way. AC behavior will change dramatically with output.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 27th November 2012, 04:53 PM   #114
I'm not going to be running the amp with no bias, I just turned it right down to see how the circuit coped with the glitch - apparently quite well.
Old 27th November 2012, 05:01 PM   #115
We mustn't get carried away This is an amplifier in a tin. I think the fact that I'm putting a mini-blameless in a tin is pushing it already
Old 27th November 2012, 05:35 PM   #116
Andrew Eckhardt is offline Andrew Eckhardt  United States
How out of date would it be to use a an IR4312 to feed power to a complimentary class A output stage? I wonder if the single channel version IR4311 could be used with asymmetrical power supplies, to save switching loss. That would require more chips though, which I guess are already breaking the rules.
Old 27th November 2012, 06:07 PM   #117
Assuming you could find some output transistors that were still linear with 5 volts across them, the minimum 1A bias current would still be burning over 20 watts for a pair of amplifiers. Getting rid of that much power in that small of a package would require a high speed fan that would make enough noise that you'd be a lot better off with the D amp chips by themselves.
Old 27th November 2012, 06:26 PM   #118
I just popped my first ever electrolytic thanks to this thread!
Old 27th November 2012, 06:33 PM   #119
keantoken's Avatar
I was replying to post 110 Bigwill.
Old 28th November 2012, 01:05 AM   #120
Originally Posted by Andrew Eckhardt View Post
. . . It would require more chips though, which I guess are already breaking the rules. . .
Chips are okay to use, and observe that this is posted in a chip amp forum.
I'm aware that you can't safely run 9w bias (18 watts bias for stereo) in a mint tin . There's hugely generous leeway for Classes Aa, AaH, AaG and other dynamic Class A. Dynamic class A that also uses adaptive power source is an extremely efficient state of the art solution that may be a future for linear audio.
There's just 2 things to watch out for:
Please don't convert the analog input signal to digital inside of the mint tin (providing an "extra" digital input is fine if the amp also has a source selector to allow the possibility of an all analog path).
The Dynamic class A amplifier (Aa, AaH, AaG, etc. . .) must pass common tests at least as nicely as Class B for the first 9 watts per channel, stereo.
For AaH, that looks like, Class A tiny bias, class a 9w (adaptive bias), but class H for headroom management at points over 9w. Right?
Contest:  Linear Power Amp in a mint tin (class Aa, class AB, or class B)Hide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 07:05 PM
Copyright ©1999-2017 diyAudio
