Old 20th November 2012, 04:19 PM   #11
johnr66 is offline johnr66  United States
Where does the green wire go on the supply in? I see only two wires off the transformer's secondary. Unless it is out of the picture, the green wire must be connected to the center tap on the transformer's secondary.
use a 40 watt bulb tester when setting this thing up.
Old 20th November 2012, 04:47 PM   #12
prezden is offline prezden  Canada
I connected the on board pot and inputs. Still humming away with no sound (music) This is most confusing
Old 20th November 2012, 08:29 PM   #13
Robert Kesh's Avatar
Originally Posted by prezden View Post
Could the damaged cap cause the hum?
yes. it is possibly shorting out whatever is connected to it.
Old 23rd November 2012, 07:49 PM   #14
Part 2: I replaced all the caps and have had 50% success. One channel is working quite well. There is a very slight hum. The other channel has no audio and a loud hum. I have narrowed the problem down somewhat. By removing one of the caps (C8) the hum is gone but there is no audio. I have tried 2 caps at this location with the same result.
I'm stumped
Old 24th November 2012, 06:17 AM   #15
Hello again- I replaced the c8 it still hums. By bridging between c8 and the output gnd the hum completely stops but there is still no audio. It's a shame because the other side sounds pretty decent.
Any ideas?
Old 24th November 2012, 07:49 AM   #16
Jay is offline Jay  Indonesia
Looks like a bridge amp PCB??
does some know how to build a 60hz hum Eliminator which stops the 60 hz hum?? prorms Solid State 21 13th August 2011 07:26 PM
Another tda2030 question pimster987 Chip Amps 3 22nd April 2011 04:55 PM
Tda2030 vs lm1875 livenicely Chip Amps 42 21st December 2009 03:39 AM
Value of capacitor for TDA2030 batista Chip Amps 3 18th May 2007 12:48 PM
Copyright ©1999-2013 diyAudio
