toroidal transfomrmer shield
Old 17th November 2012, 03:30 AM   #1
smigza is offline smigza  Australia
Default toroidal transfomrmer shield
Hi all,
I am currently building a gainclone amplifier, and would like to be able to fit everything into one enclosure. The issue I am having is that in order to achieve this I must mount one LM3875 board and the power supply regulator board near the toroidal transformer.
I have therefore decided to explore the possibility of shielding the transformer, however I am concerned that this may not provide enough EM attenuation between the transformer and the two circuit boards.
I have attached a photo which shows a draft layout, can someone please comment as to whether or not there will be any issues by choosing this design, or if I'm better off mounting the transformer in another case.
Thanks,
Steve
Old 17th November 2012, 07:59 AM   #2
bcmbob is offline bcmbob  United States
Here is a link to a build showing how one person approached the problem.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 17th November 2012, 09:45 AM   #3
Thanks for the link Bob.
Very interesting that he had no EMI coupling issues, especially when the pcb tracks were directly above the toroidal transformer and none of the audio signal lines were shielded. Kind of makes sense as the magnetic field should not leak out of the toroid, and the em field would be distributed around all of the loops.
I'm guessing that if this design worked for him, then since I am planning on having all signal cables shielded and will still put a shield around the toroid, I shouldn't have any issues then. This is good, as I can make my amp fully integrated
toroidal transfomrmer shieldHide this!Advertise here!
Where to buy step-down toroidal transformer with electrostatic shield? Kuro Power Supplies 3 15th June 2010 04:32 PM
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
shield or not shield??? Leolabs Chip Amps 13 27th July 2006 08:46 PM
metal shield dud_wity Tubes / Valves 3 11th July 2004 10:30 AM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
Copyright ©1999-2017 diyAudio
