Another "check my PCB layout" thread.
Old 16th November 2012, 11:26 AM   #1
tbj is offline tbj  United Kingdom
Default Another "check my PCB layout" thread.
Decided to build my LM3886 amp on PCBs after all, and after a few days' work I've come up with this. I've focused on keeping everything as short as possible, but working around a solder-mount heatsink I'm using (and had to draw the component for in Eagle).
Signal ground and power ground are seperated and connected only by a small trace.
If someone could let me know what they think and if there is room for improvement, I'd be ever so grateful.
The 0 ohm resistor is just a thick wire link to get the speaker output.
R
Edit: New layout - fixed problems shown below and shrunk slightly, added mounting holes.
Old 16th November 2012, 11:44 AM   #2
Hmm. OK. Just picked up on a few things myself when looking at it again.
- the trace connecting signal and power ground should be moved to the ground point in the center of the chip instead - at the moment it's in the worst possible place, especially as -
- the speaker ground doesn't have enough groundplane - I will solve this by moving the SPK pad up a bit to expose more copper.
Do your worst!
Another "check my PCB layout" thread.Hide this!Advertise here!
SymAsym - "The Sequel", AAK's Rev_1.4 PCB Builders Thread AAK Solid State 161 19th December 2016 10:23 PM
SymAsym - "The Sequel", AAK's PCB Builders Thread AAK Solid State 225 7th September 2015 05:03 PM
Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout tcpip Solid State 128 23rd September 2013 05:45 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
pcb layout for "project 68" skogs Solid State 5 8th November 2006 02:43 PM
