STK 200W PCB
Hello folks,
I am new to this forum. Attached is a picture of 2 pcb's I bought on ebay for a 5.00 Dlls. I have the components to solder onto the pcb, however I not sure how to make the thing work once I finish installing the components. How can I control the volume, inputs, outps and most importantly what kind of power supply should I use. Any suggestions I can get will be greatly appreciated.
Thank you
Hello folks,
Thank you
The board includes a power supply. It's on the left in the pic. It looks like a diode bridge and two caps.
You will need some kind of preamp to control the volume. Without knowing the schematic I can't make any specific suggestions.
I suggest that you read the datasheet for the STK chip amp if you have not done so already.
-Charlie
