Cap. at the output on bridged no DC
Old 11th November 2003, 06:57 PM   #21
GregGC is offline GregGC  Canada
Originally posted by janneman
Huh? If the bridge is properly balanced, there is no DC across the cap, right? Only AC, from the AC load current through the cap AC impedance.
Jan Didden
Look at it half wave at a time. Depending how you connected AND the value of the cap. How big the reversal voltage will be will depend on the impedance of the cap for that frequency. The lower the frequency the larger the AC voltage drop across the cap the larger the reverse voltage at every haf a cycle. For example at 20 Hz 2,200uF cap has 3.6Ohms impedance. Your speacker is 8/4 ohms. It means you coud have up to half of the output voltage across the cap at every single moment (for 4 ohms speackers).
On the other hand if you use single power supply the cap will always see the same polarity voltage with different amplitudes across.
Cap. at the output on bridged no DCHide this!Advertise here!
Measure the output of a bridged class D ocool_15 Class D 5 20th April 2008 07:12 PM
41Hz.com AMP8 - Output power when bridged MikeHunt79 Class D 8 29th March 2008 01:47 PM
Is the BASH Plate Amp Output Bridged? gmikol Subwoofers 1 26th October 2006 06:24 AM
Dual differential mode inductors in a bridged output lowpass filter BWRX Class D 3 17th November 2005 03:39 PM
Bridged amp pt.2 Gabevee Solid State 1 24th July 2002 03:11 PM
