| Chip Amps Amplifiers based on integrated circuits |
#51 |
Power off thumps from the speakers?
Check the standby circuit.
♦ Faster Home Page project ♦ ClipNipper boost ♦ Parallel LM1875 ♦ Powerful TDA7293 kit ♦ TDA7294 pt2pt ♦ My post has opinion. |
#52 |
Well preamp gave me an impact,But It has suck some treble,,I think I need compensation cap in Ne5534.I kept it empty.
IM using Fb shunt R=1K, Feedback R=22K,Low gain for Tda7294. |
#53 |
I tried 8pf in Comp. cap,,but I don't like the sound.Removed again.Treble is not strong enough.Something went wrong.
#54 |
You could try raising the gain of preamp and then adding a resistor for global negative feedback from the output of the power amp to the inverting input of the preamp. See also composite, nested designs. Check for DC offset before connecting speaker. A composite design with a Class A preamp will force the power amp to sound like Class A, in proportion to the added global negative feedback.
#55 |
Now I know the taste of music is a never ending adventure.
I have remove the classA bias,it's just the NE5534.Now I think Its a bit sweeter in treble. |
#56 |
Question: Did you have the 4.7u output cap of the preamp in series with the 1u input cap of the TDA729X?
Question: Did you put a potentiometer or other disturbance between preamp and power amp?
#57 |
I have no 4.7uf after preamp.I have two 2.2+--+2.2 uf as input cap in TDA7294.I have 10K pot for Tda7294.
#58 | |
#59 |
Loss before cap can act like tone control.
#60 |
This is not from my preamp that made a muddy treble.I think this is the tda7294 itself.Becoz when i removed preamp ,,same sound.
| LM3386: point to point or PCB? | tbj | Chip Amps | 21 | 6th November 2012 01:21 PM |
| Benifits of point to point wiring for digital circuit? | MGH | Digital Source | 15 | 14th September 2006 10:17 PM |
| Anyone use magnet wire for point to point wiring projects? | Hybrid fourdoor | Parts | 10 | 2nd February 2004 08:11 AM |
| Point to point or use a PCB | jarthel | Tubes / Valves | 13 | 10th June 2003 09:15 PM |
| Audio Note's Kit One done in point-to-point wiring | Wram | Tubes / Valves | 18 | 29th April 2003 10:59 PM |
