Point 2 Point (no PCB) for TDA7293, TDA7294, TDA7295, TDA7296. - Page 15 - diyAudio
Old 6th July 2013, 01:35 AM   #141
Originally Posted by danielwritesbac View Post
Sparks? That's construction error. The connections are a bit flimsy and voids are causing sparks, so you need MUCH THICKER traces (probably needs reinforced with wire and solid soldering).
Also, the pi filter resistors need to be paralleled with minimum pin length and not look like a fishing net.
I think I see a ground loop that might cause dulling, so that needs fixed. Hey, I've made a drawing for you.
The green traces have the conductor Thickest to Farthest caps.
Or simply use the same length of cable to each cap from the star. It pays to match.
Old 7th July 2013, 07:01 AM   #142
Default more
look
Mr Daniel...
Old 7th July 2013, 11:05 AM   #143
danielwritesbac's Avatar
Wow. That's rather genius and compact for low inductance too. Nice!
Question: What value are the four largest caps in the photos?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 7th July 2013, 08:33 PM   #144
220uf 63V was what i wanted but only had 100V
so that was used.
Old 7th July 2013, 08:46 PM   #145
Talking Thanks!
just expect those donŽt blow!
Old 7th July 2013, 08:48 PM   #146
iŽll wait to check this as is, and then add snubbers and
or smaller-bypassing-larger caps.
the one 220uf 63 that i had is for the fb-string,
should i bypass it with diodes?
and how doyou see the heatsink? what be better,
put the tabs directly onthe large Al piece?
or use the small plate first?
IŽll be using a fan fullspeed alltime, blowing into
the case and out at the other end.
Using both pieces to make U channel
Old 8th July 2013, 03:29 AM   #147
This is for double circuit, master-slave
to drive two 8 ohm speakerboxes
from fender passport 250.
Tbe used with a simple integrated
mic-line mixer, w builtin eq and efx
power derived from same psu.Need
to feed two +-12 V regs, and one
5V forthe efx module.
the mixer was brought burnt PS,
and no amp.
Old 10th July 2013, 12:54 AM   #148
Default preregs from soundwesthost
this is going slow....
Old 10th July 2013, 05:31 AM   #149
Originally Posted by martin martinez View Post
the one 220uf 63 that i had is for the fb-string, should i bypass it with diodes?
That value NFB-Shunt-Cap is small enough that it doesn't need diode bypass; however, 220u is big enough that you might want a little bypass cap for treble helper.
and how doyou see the heatsink? what be better, put the tabs directly onthe large Al piece? or use the small plate first? IŽll be using a fan fullspeed alltime, blowing into the case and out at the other end.
Well, I like it done normally. Watch out--those tabs have voltage!
Shoulder washers on tabs, tabs to insulating layer, insulating layer to big aluminum stuff, make the amp run cool stable and efficient so you can throw the fan away.
Enclosure with air intake vent and air output vent, and without needing a fan the warm heatsink will cause hot air to exit at/near enclosure top if when cool air is allowed to enter at near enclosure bottom. . . so you put the heatsink into this nonstop voluntary fanless draft of air to cool it.
Old 10th July 2013, 08:18 PM   #150
yes thanks! my problem is room temp is really hot, and amp will
most surely, be used full blast nonstop- for hours. ThatŽs why thereŽs a fan.
LM3386: point to point or PCB? tbj Chip Amps 21 6th November 2012 01:21 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Point to point or use a PCB jarthel Tubes / Valves 13 10th June 2003 09:15 PM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Copyright ©1999-2017 diyAudio
