Point 2 Point (no PCB) for TDA7293, TDA7294, TDA7295, TDA7296. - Page 14 - diyAudio
Old 30th May 2013, 06:04 PM   #131
Cool intermediate
this is what ihave
Old 30th May 2013, 06:19 PM   #132
i´ll use the boards connections, and wire jumpers over and under
board as well as P2P
Old 3rd June 2013, 07:31 AM   #133
Default more
this one for testing. No place 4 the caps!
small Power Supply.
pointo pointed...
Old 29th June 2013, 06:02 AM   #134
Default bad
dead suspect of a fAKE!
Old 29th June 2013, 06:08 AM   #135
the boards on post 131 are waiting confirmation, they´re crowded and yet more parts
tobe soldered. Anyway will finish if the chips turn tobe good not like the other pair.
Still have one p2p 7293 needto check again and test, also the parallel duo.
Old 4th July 2013, 07:10 AM   #136
danielwritesbac's Avatar
Little table radios using that "fake" (re-mark) chip usually cost in the range from $50 to $380, depending on the skill of the marketeers. When it is re-marked to TDA7294, identification is practically impossible because the IC chip package is the same. An adequate defense seems to be to start up the amp with the Light Bulb Test and also a 12+12vac transformer. If it works at the low voltage, but not at the high voltage, then you've identified it.
For this reason, I prefer the TDA7293 chips, and see if the clip indicator pin works, which it tends to do on authentic chips.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 4th July 2013, 03:51 PM   #137
Hi Daniel W! thanks.
then its better to try on low volts...
Please explain:
how would i know if #5 pin is working?
is it capable to drive a led?
I think the datasheet doesn´t show.
Old 4th July 2013, 04:26 PM   #138
The one that blew just made atiny snap, and a little
magic smoke got out.
Maybe +-35V was too much.
Old 5th July 2013, 09:45 AM   #139
Well I don't know if TDA7294S/TDA7293 could drive an LED from pin5--I just drove an old analog voltmeter with it, temporarily to see if the expected circuits existed inside the chip.
Old 6th July 2013, 01:04 AM   #140
what did the analog meter do when atached to pin 5?
LM3386: point to point or PCB? tbj Chip Amps 21 6th November 2012 01:21 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Point to point or use a PCB jarthel Tubes / Valves 13 10th June 2003 09:15 PM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Copyright ©1999-2017 diyAudio
