Old 3rd November 2003, 06:12 PM   #1
GregGC is offline GregGC  Canada
Lightbulb The Ultimat GainClone!
A MUST Conditions:
1. No DC present at the Source output.
2. The pot MUST be of a good quality or Make-Before-Brake attenuator switch.
Otherwise danger of lots of DC voltage at the output.
Old 3rd November 2003, 06:31 PM   #2
This one is not the Ultimate but it doesn't need the #2 requirement. Makes me sleep better, not relaying on mechanical perfection of the pot/switch.
Old 3rd November 2003, 07:21 PM   #3
bigparsnip's Avatar
Just a quick point, but you do realise that these circuits do go against what was mentioned before in the other thread about the resistors being mathced for the + and - inputs to ensure minimum DC offset at teht output due to the input bias currents?
Old 3rd November 2003, 07:29 PM   #4
You are absolutely right. Some people are willing to put-up with some (up to 60mV) on the output (due to the imbalance at the input that you are talking about). I think the other problem would be the unpredictability of the offset (different amps have different Ib)
I'd sacrifice some purity and use a decoupling input cap.
That’s what I'm doing.
Old 3rd November 2003, 10:58 PM   #5
i think a resistor in series with the noninverting terminal has been used for the purpose of DC offset protection. also, turning the ground for the feedback into a DC voltage will allow you to trim away the DC offset so that it is lower. this adds noise though.
if only it could be used for good, not evil...
Old 3rd November 2003, 11:02 PM   #6
Is momentary DC something to worry about?
Old 3rd November 2003, 11:03 PM   #7
bigparsnip's Avatar
Not too sure what you mean here, which resistor do you mean, one of the feedback resistors? if so I'm still not too sure how this would provide DC offset protection (unless you are refering to the value of the lower feedback resistor being equal to the input resistor?), is there any chance you could explain this one to me a bit?
Old 3rd November 2003, 11:07 PM   #8
it wouldn't be dc then would it? in anycase, DC offset causes a turn on and turn off pop in most amps. annoying.
Old 3rd November 2003, 11:08 PM   #9
in in series with the input basically. really from classic analysis it does nothing. kinda like the resistor to ground in the inverting config. ideally does nothing.
Old 3rd November 2003, 11:15 PM   #10
bigparsnip's Avatar
You mean R1?
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.10624 seconds (79.72% PHP - 20.28% MySQL) with 11 queries
