| Chip Amps Amplifiers based on integrated circuits |
hey guys i am new here and actually new in the project field. so how do i go about starting making my own amp with minimal start up price???
#2 |
Welcome to the hobby!
We have all been where you are. Need a lot of information. 1. Separate power and/or preamp. 2. Projected source - CD, Phono, Computer, DAC 3. Associated Speakers or simple earphones 4. 2 Ch stereo or multi channel 5. High quality or just general listening. A bunch more but that will be a start.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#3 |
Thanks al
1) Separate power 2)am\fm receiver+1 input jack+1 rca input 3)2 way speaker output with headphone jack 4) 2 ch stereo 5)general listening |
#4 |
Here is your headphone jack: Headphone Adaptor for Power Amplifiers
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#5 |
In consideration of a) noobness and b) minimal start-up price, I suggest just buying a secondhand AM/FM tuner to use with your DIY power amp.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#6 |
read decibel dungeon.
He has a few very affordable builds in there with much detail to help towards a successful first build. Start mono. Get it all working. Then decide how big, or small, a box is needed to get all that equipment inside, neatly and easily maintained. Finish that mono block and use it while you work on your next project. Now the real test. Try to make a stereo amplifier that works as well as that first monoblock. When you have done that, then you're ready to add on bells and whistles to make some really good well protected amplifiers. After you have all this, then you are ready to buy the second box to fit that second amplifier. with all the added bells and whistles and start listening to permanent stereo. And you will need some tools. DD may help there as well. Buy a 500gm reel of 20awg/swg 63/37 leaded solder. Last edited by AndrewT; 10th November 2012 at 01:57 PM. |
#7 |
Thoughts on the velleman K8060?
I have read some negative comments about this very simple and cheap Velleman Kit . To me it looks ideal if wanting to learn about electronics . I suspect with a little adjustment it could be made into something rather good . The power supply , case and heat sink will cost far more than the kits . If it is decided to upgrade all those parts can be reused . The BC639/640 are compatible with the pin arrangement's of Japaneses transistors ( 2SA1085 and 2SC2910 from memory ) . The output transistor could be upgraded by making a discreet Darlington . The output protection could be removed if your don't intend to party with it . Some would dislike it's 1970's simplicity . Myself , I like that . Bootstraps instead of current sources . Again I like that . Also the design is a bit more sophisticated than some would think . Velleman do say level of complexity 5 , 1 being for beginners . To be frank anything worth the effort will be of this level . I have been following a Naim Clone kit thread on DIY Audio ( NAP 140 ) . These unlike the Velleman kits would challenge a beginner . Often there is doubt about the quality of parts offered , not so Velleman . If I were teaching electronics as a night class for example this kit would be what I would choose . RS UK stock a very cheap PCB for chips like TDA2030 ( 2040 2050 ? ) . If you do a bit of reading that might be an answer . Buy Audio Amplifier Printed Circuit Boards TDA2030 PCB audioamplifier,10W 79x63.5mm One Way Circuits M12653 online from RS for next day delivery. http://www.rapidonline.com/pdf/70-4316.pdf Last edited by nigel pearson; 10th November 2012 at 03:29 PM. |
#8 |
RaHza
I'm going back to basics on a new chip flavor with this kit. You can purchase a mono setup at the same site.The vendor is very good with customer support if you get stuck. You can of course go all the way back to making your own board or breadboard assembly (per Andrew & Daniel) for even more learning and adventure
#9 |
That Jim's Audio link offers a good price for two amplifiers.
Don't use the BTL option. 180W into 8r0 indicates that each half is delivering 90W into 4r0. The single version is specified at 60W into 8r0. The difference shows that the output voltage has collapsed try to drive the 4r0 load. It will be even worse when BTL is trying to drive an 8ohms speaker. Count these as good value 60W into 8ohms amplifiers with that specified Dual Supply Rail voltage. Jim's had very poor customer support in the past. Many builders had to look here to try to sort their kit builds. Things seemed to have improved judging by the (infrequent) reports I have seen on the Forum more recently. Last edited by AndrewT; 10th November 2012 at 05:02 PM. |
#10 |
Same thing from a different vendor. This guy is currently active on this forum.
| Basic Sub for Ariels | Doug R | Subwoofers | 5 | 20th February 2010 04:17 AM |
| Basic 2 way or D'applito | Holty | Multi-Way | 1 | 16th April 2007 08:44 AM |
| Amp6 Basic | Dennis Hui | Class D | 10 | 27th September 2006 02:27 AM |
| Basic Information | thenoffya | Multi-Way | 7 | 14th March 2006 11:02 PM |
| A basic chipamp in a not so basic case. | waltson | Chip Amps | 19 | 24th August 2005 07:40 AM |
