Basic
Basic
Old 17th November 2012, 12:02 PM   #41
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Thanks for alerting me to that ESP page. It has some info I was looking for but couldn't find on my bookshelf. I need to integrate it with what I'd been reading before I take in the Yamaha paper.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 17th November 2012, 12:22 PM   #42
bcmbob is offline bcmbob  United States
KD, I looked at that kit and don't understand how it would offer more learning opportunities than a chip based amp. If "learning along the way" means modifying/changing components on the supplied board, the MyRef threads contain hundreds of those examples.
Please explain if you would. I'm gathering from this thread the point-to point or breadboard approaches are the most useful methods if one wants to really dig in and learn.
Ex: Fremen Beta thread.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 18th November 2012, 09:42 AM   #43
KatieandDad is online now KatieandDad  United Kingdom
KatieandDad's Avatar
It depends on wether you want a Class A/B Chip Amp or a Class A Discrete Component Amplifier.
The JLH / Hiraga is a VERY GOOD design and "Bang for Buck" you'll be very pleased with the results.
IMO Chip Amps are cheap and cheerful and can be disappointing.
Class A has its drawbacks but these are not sonic. ie you will need a bigger power supply and you will need bigger heatsinks.
Try not to get drawn down the POWER argument at this stage in your learning process. 10W of RMS power is more than enough to annoy the neighbors. 100W is only twice as loud.
I did build an LM3886 Chip-Amp a few years ago to listen to while I was modifying my real Hi-Fi. It was OK but nothing special.
If you realy want to enter the super-league at the bottom end, have a go at an F5. All the boards are available on this site and there are more threads than an old jumper to help you build it.
Old 18th November 2012, 09:51 AM   #44
nigel pearson is offline nigel pearson  United Kingdom
Hi KD . As I said before the only impediment to success when young was my soldering skills . Alas that is true again .
This is what I can find of my JLH inspired 8 W class A amp . 8 Watts was the old definition of hi fi . It becomes an AB amp above that . The parts were ones I had rather than some brilliant plan . This was never intended for showing to others so forgive the way I draw it . I had a better version which I seem to have lost . All graphs are real . 2 x 30 000 uF PSU . 50 uW is an interesting way to measure amps if wondering ( hum / distortion ) . The red 12 R resistor I felt to be critical ( it can be 0R ) . This was built point to point as it saved time mostly . Forgive full size , required for detail . I had an amp based on OPA 604 and complimentary feedback pairs . This one beat it even on measurements . The odd frequencies are due to me substituting a NE5532 op amp for TLO72 in my home-brew oscillator I seem to remember . 5532 is better than I guessed !
Forgot to say . Output capacitor is a precaution . It wasn't required . It was to be made smaller as part of a crossover to a mid range speaker . The final version was from memory - 66dB distortion at any frequency and any level of power ( A or AB using 1 A standing current ) . The strange VAS feedback helped that .
Old 18th November 2012, 11:41 AM   #45
Nigel, I have seen some variations of the JLH and Hiraga Class A amplifiers but I've never seen anything so different to the diagram that you have posted.
This is the classic Hiraga 8W - Unfortunately most of the components are now obsolete.
Old 18th November 2012, 11:48 AM   #46
KD - Was just looking at this. How does it compare to yours?
15W unit also available.
Bob M.
Old 18th November 2012, 11:55 AM   #47
Looks like a take on the classic Hiraga Circuit. Do bear in mind that the supplied heatsinks are only for the driver transistors and not the output transistors.
This design always gives pleasing results so you wont be disappointed.
Are you happy with the demands of a Class A amplifier ?
A stereo 10 + 10W Class A amplifier might well need 100W plus of PSU. (Not enormous but it all adds up).
I run a 100 + 100W Class A amplifier, each channel has a 750W PSU.
Have a little snoop around this site http://sound.au.com/tcaas/index.htm
Old 18th November 2012, 12:05 PM   #48
Yes, I see the bare output transistors in the second to last picture.
So you are saying your amps are doing a 1200W heat loss? (750 *2 = 1500 - 100 * 2 = 200 == 1200). Or am I not understanding correctly?
BTW; Anything here look like a good match for the 30W?
Bob M.
Old 18th November 2012, 12:14 PM   #49
You're not far off the mark.
The 2 Class A amps are actually dissipating about 400W of heat, the remainder of the PSU capacity is for "Headroom", it gives the amps the ability to draw large currents when required.
I won't go into it here but the larger PSU also has lower impedance which helps bass transients.
A 750W PSU is capable of producing 750W - that doesn't mean it is always producing 750W
Old 18th November 2012, 12:15 PM   #50
Thanks, I may be hooked.
Bob M.
BasicHide this!Advertise here!
Basic Sub for Ariels Doug R Subwoofers 5 20th February 2010 04:17 AM
Basic 2 way or D'applito Holty Multi-Way 1 16th April 2007 08:44 AM
Amp6 Basic Dennis Hui Class D 10 27th September 2006 02:27 AM
Basic Information thenoffya Multi-Way 7 14th March 2006 11:02 PM
A basic chipamp in a not so basic case. waltson Chip Amps 19 24th August 2005 07:40 AM
